Question about Siemens CF62
Connecting my siemens cf 62 to the internet.
I am a subscriber to Zain one of our communication systems providers. I took my Siemens cf 62 to their shop to have it connected to the internet; but I wa told that they had filed to do so because the cf62 is complicated. They tried to configure it by remote control but it has not responded satisfactorily. Each time I test the phone on the internet I get the following responces:
1 HTTP error 502 Bad gate
2.Error server not responding
3. CSD failure
4.GPRS failue
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
Free unlock code for siemens cf 62
try code from service provider...................
Sep 23, 2011 | Siemens CF62T Cellular Phone
Cannot locate modem access code for my 4200 and i cannot set it up on mypc without the code
Hello anp1922,
I haven't used a Siemens SpeedStream Modem for some time now. My son replaced the modem we received from our internet provider when we first subscribed. We now use a NetGear Wireless Router. On the NetGear's, there's usually information that explains how to log in to the router such as a User Name and a Password.
Now on your Siemens SpeedStream Modem, it may not exactly be the same. I can't remember if the Siemens had the same setup and I'm sure you would have checked already by now. My guess is that you probably would need the software that came with the modem in the first place. A lot of times your internet provider, especially if it's DSL, will provide you with the router. I would call them and ask them for assistance. They can usually help you best. If you bought the IP Router yourself, then they won't help you and you're best to call the manufacturer. Hopefully Siemens doesn't ask you to pay for their service. You most likely will speak with someone in India who is in training.
I know I haven't completely answered your question but I am willing to help you out if you desire. GOOD LUCK.
Sep 06, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
I have a k850i. how do i setup my internet assess? i am i nigeria and my network is zain
Dear Friend,
There is Two Ways to Configure.One is By sending SMS &Other is Manual Configuring...
First you have to Send Message like Following.....
  • Send an SMS with the text INTERNET with your phone make and model to 232.
  • For example, for Nokia 9300i: Send internet(Space)nokia 9300i to 232. (You have to Send INTERNET SONY ERICSSON K850i(To 232)
  • When your settings arrive choose the option to save it. If prompted for a PIN, use 0 (zero). If prompted for a longer pin use 0000
  1. Home page:
  2. Port:8080
  3. Access point
  4. User name: (Keep blank)
  5. Password :(Keep blank)
  6. Authentication : Normal
For MORE assistance on HOW TO ACTIVATE the service, call customer care toll free on 131 for postpaid subscribers and 111 for pre-paid subscribers.
I like To KNOW FEEDBACK.......
I hope THIS HELPED YOU... If So Do Rate mE.... Thank you for Contacting FixYa..Keep using.....
Apr 08, 2010 | Sony Ericsson K800i Cellular Phone
I have china mobile model. n82i .internet problem
download the internet setting provided by your network provider also download the setting for nokia handsets those are the only handset model of nokia recognized by your network service provider.
Sep 10, 2009 | Siemens M56 Earbud Hands Free Headset
Want to unlock Siemens Dual Phone DP450
How To Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the phone from the Tesco Internet Phone service. This will enable the phone to be used with other Internet Telephone services. This follows the recent news that the Tesco Internet Phone service is to be ceased from April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450 defined and released by Gigaset Communications, the original supplier of the phone to Tesco. If this procedure is not followed exactly your phone might not work anymore. In this case Gigaset Communications cannot accept any warranty claims.
Unlock procedure
Your Phone should have the latest released Tesco software version, else this unlock procedure will not work.
On your handset:
Select and press OK Enter the system PIN (0000) and press OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the following service code. Please use the exact code as is described below, else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now "Eeprom" must be displayed)
Insert the following number sequence: 01778 06183 06191 Press OK to finish the programming. "Saved" must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail firmware version.
SETTING > BASE 94762001 (Now "Eeprom" must be displayed)
Now insert this number sequence: 04850 04351 04864 Press OK to finish the programming. "Saved" must be displayed on the Handset.
After this procedure you can upgrade your phone to use the latest retail firmware version.
Please Note: The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone service, if you want to change this to set the default to the land line you need to change this in the web interface from your phone. How to do this, download the Gigaset S450 IP manual from the Gigaset web-site URL: ... nuals.html
Smith Online
Apr 11, 2009 | Lands Phones
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
Help me
Dec 18, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Will not connect
First, I would make sure you are using the right type of patch cable to connect to your cable/dsl modem. There are two types: 1) Straight through 2) Cross over The manual for this device says to use #1 when connecting directly to a computer, and #2 when connecting to a hub. If the cable/dsl modem is powered on and you are not receiving a link light on either the cable/dsl modem or your computer, try using a different cable. If this does not work, then you may have a problem with the device itself. At that point, call your Internet Service Provider, as they may be able to provide you with a replacement. If you did not receive this device from an ISP, then you will have to contact the manufacturer directly. Unfortunately, it looks like Efficient Networks was bought by Siemens, so you may have a hard time receiving support from them.
Sep 15, 2006 | Efficient Networks SpeedStream 5667...
Cell Phones Logo
158 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
