Question about Alpine CVA-1005 Car Video Player
Ive got the cva1005 with the brain an i need the whole wiring setup for the whole system. where do i find it?
On ebay
Posted on Mar 17, 2010
I turn the key and it just turns over but wont try to start. ive replaced the fuel pump the fuel pump relay. its geting fire cause i can see a ark on 1 of the plug wires. ive poured fuel directly into the...
a 1997 c1500 doesnt have a carb it is fuel injected, you poured fuel into the throttle body. when you turn the key to the start position and you do not hear the fuel pump you could have a blown fuse. if not, all chevys have passlock a passive antitheft system that have locked the fuel system down. check some remote start companies on the internet you will find one with a wiring diagram, you can figure out the rest from there. its eas
help from the BIG BRAIN
Dec 26, 2010 | 1997 Chevrolet C1500
Im out of options someone help
just a suggestion. go back to the simple things. get a wiring diagram. can be found in haynes repair manual at a parts store and start tracking voltage from the battery to starter to ign etc. sounds like ignition to me.
Jun 11, 2010 | 1998 Chevrolet Camaro
Do not have instructions to set-up Seco Larm correctly.
3 different ways:
1.On-board dial for adjustment
2.A separate shock sensor with dial connected to alarm brain with 3-4 wires.
3.Newer models have a digital shock sensor which is adjusted by the remote
Apr 02, 2010 | Vehicle Parts & Accessories
Eclipse 7002MT dvd system manual
Yes I need a brain and a wiring harness. How much do you want for both? Please post and let me know. Sean
Sep 19, 2009 | Car Audio & Video
There was an old security system in my truck prior to me buying it and ive had it for six months and today i tried to start it and it wouldnt even make a noise turnig the ignition except for the radio and...
is the alarm factory or aftermarket?
If aftermarket - the brain will be under the dash attached somewhere near the steering column.
Look for an 10 or 12 Gauge YELLOW wire that has been cut.
This is your starter wire.
one half goes in one side of the brain, and the other comes out the other side.
either solder or use crimp-connectors to return this yellow wire back to factory.
If you no longer require the alarm - you can do the same for every other wire on the brain.
Here is the color code chart for your vehicle...
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness
Ignition 3 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White Coil
Brake Switch White Brake Switch
Trunk Release Brown Switch or Driver's Kick Panel
Trunk Pin DIESEL- Glow Connector Blue behind Instrument Cluster
Parking Lights Brown (+) Light Switch
Head Lamp Yellow (+) Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Purple (-) 4 Pin Black Connector Driver's Kick Panel
Door Lock Light Blue Driver's Kick Panel w/Keyless Positive
Door Unlock White W/o Keyless Entry Reverse Polarity (5 Wire)
Horn Wire Black (-) Steering Column
Windows Up LF=Blue, RF=Light Blue
Windows Down LF=Brown, RF=Tan
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | 1995 GMC Sierra C1500
Alpine cva-1005
Get a TR-7 device from ebay. for 20 bucks it will bypass the parking break by issuing the correct sequence allowing you to view video while driving. However, remember many states outlaw this type of operation. They are specifically designed for the CVA1005 though.
Sep 28, 2008 | Alpine CVA-1005 Car Video Player
I need the brain unit and wires,for a KVT-915 DVD
best bet ebay keep serching on ther ok for broke one or missing screen one ok
Feb 09, 2008 | Kenwood Excelon KVT-915DVD Car DVD Player
Alpine CVA-1005 Car Video Player Logo
152 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
