Question about Star Heating & Cooling
Model KFR-60GW/A remote control could not start. Changing a battery stil not working. On/0ff still no go. Is there anyway I can start without the remote. However, cannot find the button form the unit
    President:
  • 1,515 Answers
Hi, I couldn't find anything in English as the unit is made in china and all I could find was in China. You should have a touch screen on the front to turn it on and off. If not. I will continue to see what I can find on this unit.
Shastalaker7
Posted on Jan 30, 2010
I need to know to do after changing the batteries in my remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Hello, what is palladine tv model EPT 3250M remote version
There is no way to make it unlock; without its remote control.
Apr 10, 2014 | Universal Remote Control Remote Control
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
How to opertate toptv without remote
1) If difficult to do this without remote control, you will have limited operations.
2) Retight the spring contact batteries and clean very well with special spray contact
3) Resolder the wires contact batteries.
4) Try again with the code go for to downloa: www. fitness.manualsonline.com
5) Otherwise you must go the remote to repair shop.
God bless you
May 09, 2012 | Televison & Video
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
I dont have my celestial KFR-28GW\A remote control
Hi, the best way to tell without the manual, would to be to pick up a anolog thermometer, and insert it into the face of the a/c. This will tell you which setting will give you cooler air temperature. They are very inexpensive, and you can get them at most any hardware store or appliance parts store. This will be useful in your auto a/c, refrigerator and so forth. Best of Luck, and Happy Holidays,
Shastalaker7
Dec 17, 2009 | Heating & Cooling
CAN'T TURN ON MY PHILIPS 42FD9925/01 SCREEN, ALWAYS IN STANDBAY
Did this solution work as I have the same model and same problem and I have ordered the remote from philips suppliers
Jun 20, 2009 | Philips 42FD9932 42 in. Plasma Television
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Heating & Cooling Logo
232 people viewed this question
Top Star Heating & Cooling Experts
Paul Carew
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you a Star Heating and Cooling Expert? Answer questions, earn points and help others
