Question about Dell PowerEdge 4600 Server
Doesn't boot/post Hi, I have very strange problem with my server. last week it wasn't powered on, and now it doesn't boot/POST. what i mean, that display is not powering on, keyboard is not working, and nothing is working. In LCD on server where are no errors shown, but if i make something (like rip off one CPU or memory bank), it recognizes the problem and shows it on LCD. no beeps are produced, so i am lost, because i don't know were is the problem :( i checked it with diffrent video card (old PCI), but it seems not the problem (not working also). Could somebody tell me where to look the problem ?
  • 3 more comments
  • wanis Feb 28, 2008
    LCD doesn't show any error, and it doesn't post enough to get to the system diagnostics. I will try with diagnostics CD and write here an answer :) thanks
  • wanis Mar 24, 2008
    well My server is dead :) i went to hardware support, and they didn't found any suggestion why it is not working. after talking to support, we decided that the BIOS is dead in some misc way. But there are two flash'es so we didn't do anything, and i got new server :) Thanks for all your help :)
  • wahba Sep 17, 2008
    The server doesn't boot and when I accessed the container configuration utility - clicked manage containers; my RAID 5 (136.7GB) container is dead and has 2 missing members out of 3. The 3rd one is 68.3GB is detected.
  • cyford Feb 28, 2009
    i have the same issue, looked like it was the cmos battery before.. so i replaced it and rest the nvram, it let me boot to the bios 1 time then never again
  • William Cline May 11, 2010
    Is there any error code displayed on the front LCD panel? Does it POST enough to get to the system diagnostics (F10)? If not you can create a set of diagnostics diskettes using the Dell OpenManage Server Assistant CD. Boot the first diag disc and run the system diagnostics. This is a handy link: http://support.dell.com/support/edocs/sy...
Make all the critical updates that Dell propose to your machine
Posted on Mar 20, 2008
What is 3-3-2 beep tone meaning
System doeIf there is one DIMM in the system the memory row/bank may be disabled when there is a memory failure. The system will not boot because it has no memory to use. If the DIMM is replaced with one of the exact same type and size, then the system will continue not to boot. BIOS cannot tell when a DIMM has been replaced with one of the exact type and size, therefore BIOS believes it is still the bad DIMM and will not use it.
Here are two possible workarounds:
1. After replacing the defective DIMM, continue to reboot the system until you hear the "no memory" post beep sequence (3-3-3) during POST (no video display). After three (3) incomplete boots, a "062 three consecutive boot failure. Using default CMOS configuration caches are off" error will occur. At this point BIOS will go back to the default settings and begin to use the new DIMM. However, if you have disabled the 3 boot fail count (this setting may not be available in all servers) in Setup, then BIOS will not turn the DIMM row/bank back on.
-=OR=
2. Remove the DIMM. Power on the system until the "no memory" post beep sequence (3-3-3) is heard. The memory row/bank will now be marked as being empty. Power off the system and put a good DIMM back into the system. The memory DIMM row/bank is re-enabled and the system boots normally.
NOTE: If more than one DIMM (or more than one DIMM set) is installed in the server and one memory (or one memory set) row/bank is disabled due to a memory failure then, the user must go into setup and re-enable the row/bank after replacing the bad DIMM.
Additional information
s not boot after replacing memory DIMM Servers
Jun 11, 2014 | IBM Netfinity 5600 8664 Server
My dell poweredge 2600 wont load up
  1. Can you access the Bios configuration on boot by pressing F2? Check the setting
  2. By load up do you mean your server software does not boot? use F10 on post from the utility partition main menu under Run System Utilities.
  3. Is the server working with RAID? Press CTRL + R and check the RAID
I am not going to say check all the cables because I am sure you will have already?!?
Aug 21, 2013 | Dell PowerEdge 2600 Server
Hello, I have a problem with: Machine is HP netserver E800 Runs MS W2k SBS. Hardware ? single PIII 933, board supports second processor IDE onboard controller with CD Problem booting up....
why not ask HP this. and not on the chat forums here,
this is NOT HP. not in the very least.
F2 sounds me , its the command to reload the OS.
did you lose the manuals on this server?
it tells you what F2 means, id be there in a heart beat at hP
in fact id down load all books on it now, because soon or now
there will be no PIII books at all, its a relic, pentium 3.
Can you boot to say a linux live CD.
or a window PE live cd?
your server will not boot to USB so, that out. (modern ways)
if yes your OS is dead, or HDD dead.
reload the OS. now. try that using the books for this server.
is it RAID? or one IDE disk.?
what does CD problem mean
why not tell the helper why is a CD in your hand
and how made it and if and OS install who's , HP or microsoft
we can not guess what you are attempting with CD in hand.
if the CD will not boot 3 disks,
1: yours.
2: linux live
3: windows live.
then the CD drive is dead, or you need DVD drive.
the newer OS needs a DVD drive, for sure.
i think (omg long ago) windows 2000 is on 800mb CD.
to boot CD you must tell BIOS to boot there first. force it.
true on all PCs and now impossible (near) with W10 and UEFI and secure boot enabled, (said or watchers looking here)
get a test CD with LINUX and test the boot.
this proves it can boot and BIOS is using it.
POST - memory count
power on self test or POST??????????????????
is this a BSOD , blue screen of ***** off a new CD from HP?
if yes the CD drive is DEAD< end of life gone and now reads corrupted data, as most do this old, buy a new CD drive.
now.
this BSOD if is, can be seen on 1000000 of posts (messages about POST, LOL where the guy doing it, used CD-r disk that are pure JUNK> or a burner old that is trashed.
please post here X your P.O.S.T screen,. I always wanted to say that.
there you go.
May 25, 2017 | HP NetServer E800
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
POST errors forcing server to crash
Its best you log a case with HP support. If your system is still under warranty or if you bought support along with the system, they will fix the problem for you.
Apr 01, 2010 | HP ProLiant DL380 G5 Server
My E-Machines desktop just stopped working. A few weeks ago, my user was corrupted so I had to do a system restore to get to my data on hard drive. Did that and backed up to external drive and it worked...
that beep means POST.. your computer hardware is fine .. please just re install the operating systemm... before that you might want to back up the hard drive data using bartpe or some tools similar to that.. if you dont have that expertise. just re install the operating system .. you should get back to work...
remember beep meaning POST meaning your hardware is fine.. the operating system is just corrupted / broekn
May 13, 2009 | E-Machines eMachines Desktop PC
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
Boot Problems... Complicated...
The IBM Netfinity 5600 is a complicated beast for sure. You really need to get a copy of the Netfinity Manual from IBM (not on the web site fyi.). It's as big as the machine unfortunately. In section 3, p.124 it lists 3-3-3 beep code as "No memory has been detected in the system" solution is "Reseat mem modules or install mem modules. If prob persists get machine serviced." On the previous page, 3 short beeps (only) on POST indicate "system mem error. combo only occurs when video bios cannot display error msg. replace the failing mem module." You might also want to check the light-path diagnostics inside the machine. A little light will be illuminated right beside the bad DIMM.
Jun 06, 2008 | IBM Netfinity 5600 8664 Server
Server shuts off.
pls try to chek to power pack for malfunctioning if it is replace the power pack with a better one
Apr 03, 2008 | Dell PowerEdge 2600 Server
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Dell PowerEdge 4600 Server Logo
330 people viewed this question
Alun Cox
