Question about Elna Sewing Machines
ELNA 7000 no display on screen
ELNA 7000 Worked perfectly yesterday. Switched on mains; motor works so does bobbin winder but no display on the screen. Can anyone help to 'reboot' please. Have looked at bobbin area and cleaned out fluff etc. Wendy
Problem solved - I have a useful son! he took off the casing & cleaned 'circuits' . Now works fine. Wendy
Posted on Feb 01, 2010
My elna 7000 sewing machine does not want to wind the cotton
Not sure of the particular bobbin winding problem you are experiencing. However, frequently the bobbin winder "tire" becomes worn and needs to be replaced.
Elna 7000 Parts
What is the correct way to wind and insert bobbin in elna machine
Jul 20, 2016 | Elna Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
Problem with ELNA 6200
That symbol indicates the bobbin winder is engaged. disengage the bobbin winder, all should be good. If not the micro switch that indicates the bobbin winder is engaged (when it's not) may need adjust or replacement. See a tech
Feb 11, 2014 | Elna Sewing Machines
Elna lotus tsp
I would really suggest having the machines bobbin winder checked at a sewing machine repair shop..
Jul 10, 2013 | Sewing Machines
I had a zigzag problem with Elna SU Electronic Air, which I fixed with your solution, but some of the unfreeze liquid had gone down the bobbin winder hole and now the outer wheel on the right side wil
is the belt slipping now? You'll probably need to take off the top cover and see if you can clean up the spilt lubricant off the bobbin winder mechanisim and the drive belt on the right of this. The bobbin winder is friction driven, a rubber ring around a plastic barrel and when you click this over to the right the rubber ring drives off the main drive part of the machine.
removing the top panel is a bit tricky because you've got the handle there too, two screws unscrew it, then you need to manouvere the cover upwards and left to get it out of the bobbin feed part then tip it to the back of the machine to give you a view of the inners. You might want to subscribe to the Yahoo group called "Elna Heirlooms" as there's probably a prior thread on this there, lots of Swiss Elna owners who service their own machines, very useful place to visit.
May 15, 2012 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Dec 26, 2008 | Elna Quilter's Dream 6003Q
Bobbin winder is stuck
It seems that the bobbin winder sensor needs adjusting and is best done by a service technician with the appropriate service manual to ensure correct parameters are achieved..........to locate your nearest Elna dealer, try ElnaUSA .....here
Feb 16, 2008 | Elna Quilter's Dream 6003Q
Elna 7000 computerized sewing machine
just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
Oct 20, 2007 | Sewing Machines
Sewing Machines Logo
243 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
