Question about Sony STR-DE135 Receiver
Sony STR-DE135: No audio output
I've been moving a lot the past year or so and after I moved into my last place, I found that I could no longer get any output from my Sony STR-DE135 Receiver. The receiver still turns on and everything, but I really know very little about stereo repair, so if someone could at least give me a place to start looking at for troubleshooting help, I would appreciate it.
  • travelhappy0 Sep 30, 2008
    I found that turning the volume WAAAAAAY up momentarily restored teh audio output. It's keeps happening, though. I presume it is relays.
    Sergeant:
  • 395 Answers
First, at turn on you should hear a relay click then a few seconds later a second click. if you should hear the two relay clicks then check to see if you have both A and B speakers on, if you do shut B speaker off. next check the tape monitor switch make sure that it is off. if you should not hear the second relay click you have a problem with the unit and needs to be repaired.
Posted on Feb 17, 2008
I have a sony STR-de135 receiver whlie looking for one problem created another.While the receiver was unpluged I touched and output transistor MN2488 and it sparked now the left channel sounds distorted so...
The capicitors in the unit are charged. Replacing the output transistor(s) is not a task for a novist. Capicitors, resistors, driver transistors and sometime preamp chips can also be bad as well. If all the bad components are not replaced the parts you replace could blow out again.
Jun 19, 2010 | Sony STR-DE135 Receiver
Want to play my ipod through sony str-de135 receiver
Get a headpone to rca cable (radio shack or best buy) and use any input on the rear of the receiver except phono. You will need to turn the ipod to near max volume.
Nov 28, 2009 | Sony STR-DE135 Receiver
On the display of my sony str-de135 appears the word"protect" and then the cd does not work. what must I do ?
your speaker wires are grounding out on something or you have popped an internal fuse or youve burnt the power supply refer to your manuel
Oct 07, 2009 | Sony STR-DE135 Receiver
SONY STR-DE125 READS PROTECTED
protection is designed to protect the output transistors from, shorted speaker wires, shorted speakers, too low speaker impediance,make sure the amp is well ventilated.
turn the amp off for 1 to 2 hours to allow thermal reset if this fails most likley some internal damage has occured and the unit will need to be serviced
Sep 02, 2009 | Sony STR-DE135 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
My Sony STR-DE135 reciever has sever distortion on the right channel speakers (A&B) no matter which input is selected. I can not find any obvious fault on the board. Any tips to help me fix it?
It sounds like your receiver may have a damaged output IC. I'm assuming that you've already tried a known good speaker on the right channel but if not, that would be a good idea. Also check and verify that the speaker wire is not damaged and that the terminals at each end are securely fastened.
Good Luck,
BB
May 16, 2009 | Sony STR-DE135 Receiver
Audio out problem
sounds like your sound output ic may have gone.this is normally connected to a heat sink.also check that sound output settings are ok before you go further
Feb 08, 2009 | Sony STR-DB780 Receiver
No power -- bad power supply?
The fuse thats leads to the power supply on the sony receiver blows everytime i try to plug in the receiver. What makes this happen and what can i do to get the receiver going again. Model STR-DE135.
Jul 02, 2008 | Sony STR-DE135 Receiver
Sony STR-DE135 Receiver Logo
358 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
