Question about IBM ThinkPad R51 Notebook
My laptop will not turn on at all
I've tried everything to get my IBM thinkpad to turn of from removing the battery cleaning posts running it on main only, nothing works. the whole 10 times button thing didn't work either. Its a model R51 type 2887. I am poor college kid and that laptop has 150 pages of a book I've been writing!!!!!!!
    President:
  • 2,022 Answers
Have you remove the ram and try .
Posted on Jan 30, 2010
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: IBM thinkpad R51 2887 -nq8 model bluetooth drivers
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link :- http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Posted on Jun 16, 2009
My IBM Thinkpad won't turn on after improper shutdown.
Always check power supply first. Ensure green/orange charging light appears in the LED bank near the screen bottom when adapter is plugged in. If NOT then charger or battery (or motherboard) is faulty.
A dead battery shouldn't cause a shutdown, so the charger is the first suspect. The yellow power socket can become 'rusty' in some cases so inspect this also. If the contacts inside aren't clean & shiny then try some WD40 after scraping gently with a 1 or 2mm flatblade screwdriver (with the battery OUT). If not even a P.O.S.T. (Power On Self Test - IBM logo)
appears with the CDROM and Hard Drive removed, Try cleaning the memory and swapping its position on the back of the unit. Good Luck.
Jan 24, 2014 | IBM ThinkPad T20 2647 Notebook
Tip
IBM Laptop Battery Power Saving Tips
How to try to extend the battery life are much concerned by many laptop users. Utilizing some small skills and minimize unnecessary waste of battery during the using process can make you full use of your laptop battery power.
The engineers of IBM personal computer business division give vast laptop users some good suggestions here to ensure that you can maximum extend laptop battery utility time. Therefore, it will improve your work efficiency; let you enjoy mobile office work and entertainment pleasure without limits.
IBM batteries on sale :
IBM thinkpad t40 Battery £ 37.52
ibm thinkpad t41 battery US $ 41.24
ibm thinkpad r60 battery. US $ 71.27
IBM ThinkPad T60 Battery £ 38.51
* Turn down the brightness of the screen. At the same time, although IBM ThinkPad laptop keyboard is equipped with lights, ThinkLight, but in order to save power, it is better to turn on it when under darkness conditions.
* When not using the wireless receiver device, turn it off please.
* Some users like opening CD or DVD to play music anytime, the power of battery will flow away quietly along with the music playing. Suggest everybody turn on the music only under the situation that they do want to enjoy the music.
* When the battery during using process, try to fully charge and discharge the battery.
* Try to avoid using it under high temperature and low temperature, for example, when you enjoy sunshine on the beach, please don’t leave your laptop in the car to enjoy SAUNA.
* Use proper AC adapter for your ThinkPad laptop.
* Use the IBM ThinkPad battery Battery MaxiMiser management software you select the most suitable for the extension of the power program.
* Use the IBM ThinkPad battery management software – Battery MaxiMiser, select the power extension program which suitable for you.
* Setup the standby time of monitor, hard disk and system sleep time, because it is no need to let your laptop still running at full load when you are at non-working stage.
* Under the Intel SpeedStep technology effect situation, the processor based on the current load situation adjusts the speed automatically to save battery power overall.
In fact, the laptop battery is a spiritual guy, after got expert advices, please treat it properly, it will bring you to enjoy a better mobile life.
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
on Jun 04, 2010 | Computers & Internet
Battery light on nothing else
Has there been ANY damage? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged it? Unplug, remove battery, plug in, try to reboot. Has it been overheating? Fan, vents, heatsink clean?
May 06, 2013 | IBM Lenovo ThinkPad T400 Notebook
I have an older ibm thinkpad laptop, Tried to add memory, a new fan The power and fan and hard drive started , then powers down
Hi There,
Make sure all of your connections are tight, and that the RAM, HD connector, and anything else you've touched is seated correctly.
If you tried to put more RAM in than the computer will allow, it will not turn on. If you've unclipped a wire somewhere or your RAM isn't seated correctly, it will malfunction.
Check and then double check everything.
Jul 16, 2012 | IBM Thinkpad T43/p Notebook
Ibm thinkpad R52 laptop no powering on, adapter is ok.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 26, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.
Remove battery and power for a minit, install it again, power up mains and try again. This helpe me here in Paraguay several times.
Saludos Wolfgang
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
My IBM Thinkpad T40 2723 will not boot up
The first thing to try is to unplug the power adapter from the computer then remove the battery. Then press down the power on button for a second or two. Put the battery back in and reconnect the power adapter and see if it boots.
Mar 26, 2009 | IBM ThinkPad T40 2373 Notebook
Barck the Power On Password
You MIGHT be able to get rid of the password by doing the following: Unplug the AC adapter. Remove the main battery. Find and remove the CMOS battery. Leave it like that for an hour. Put everything back. It will either work or it won't.
Mar 02, 2009 | IBM ThinkPad T41 Notebook
Total failure of IBM Thinkpad R50 after connecting sony clie PDA
Your colleagues are correct, the problem with laptops is that the motherboard and powersupply are integrated,
if there is a seperate powerboard, usually the mains inlet runs through the mainboard itself to get to it. As it,s located under the touchpad. ( On certain Models )
What you,ve actually done is put an input current into your motherboard via the USB.
These are designed to output 5v pos And 5v negative. + 2 x Data transfer/signal in/out.
If you take this in for repair, you,ll be looking at £75+ Or $150+ Depending where you are. Just to Be Looked At.
For them to possibly charge you an additional £200+ Or $400 for a new motherboard.
Sorry for the Bad-News but i,d advise looking into buying a replacement laptop, and put it down to experience.
Mike @ Compurepair.
Posted @ 09.20 AM ( G.M.T )
Mar 05, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad R51 Notebook Logo
276 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
