Question about Epson CX8400 All-In-One InkJet Printer
Printing photos My photos look like they have little squares thru the entire photo
  • 33 Answers
That is called pixelation and is usually the result of enlarging a photo, whether it be resized larger on the computer or printed at a larger size than it's original pixel dimensions.
Check your printer settings for a setting like "resize photo to fit paper" and uncheck it. Or print from a photo that is larger than the paper and it will reduce the size without any pixelation.
With digital photos you can always go smaller than the original, but rarely ever larger.
Posted on Feb 17, 2008
Can I print small photos Using 4x6 photo paper??
you can print more photos per page but it requires you to set up the page and the number of photos on the page
one of your photo shop programs will have that ability and it will take some trial and error to get the right results
basically it will work like this select a photo and insert it on to a page
select another photo and insert it onto the same page next to the first one and so on until you have a page full
the page can be sectioned into squares as well
when you have what you want go to print preview and if that is working then print
after that use a sliding paper cutter to cut the photos from the page
Sep 04, 2016 | HP Envy 4500 e-All-In-One Printer, Copier,...
How to make date etc appear on back of photos
The date usually only appears on the front. However, most retail photo labs (i.e. walmart) can add custom backprinting to your photos. You can usually only add one line of text for entire order and custom pricing would probably make this a little bit expensive. On that note, the date you have your film developed/printed is usually printed on the back of each print for free, as this is default setting for the lab's printer.
Feb 17, 2010 | Pentax Photography
Hp 8500-printing yellow lines across photo prints
I have an HP 8500 printer. When printing photos it prints lines spaced 1" apart accross the entire photo?
Dan
Oct 31, 2009 | HP LaserJet 8500 Color Printer
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
Oct 29, 2009 | Epson Stylus Photo 1280 InkJet Printer
Just purchased esp printer, does this have to be
You do not need to connect it to computer to print photos. the printer, place any document on the scanner glass and put papers in the document tray and press copy. if the printer does not work, Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.The usb cable does not comes with the printer and you need to purchase it additionally
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Why does the entire photo printout with a pinkage color overlay when indicating using glossy photo paper, even different photo paper. This occurs with several different programs not just Photoshop. I've...
That happens if you put photo cyan where the plain cyan ink should be, also photo magenta is too weak to be used in the magenta slot. I've also seen generic inks that weren't the right colors.
Jul 09, 2009 | Canon i9900 InkJet Photo Printer
Lines thru photos
Try to clean the nozzles with the printer troubleshooter. It will force all the nozzles to print at maximum quality and will clean the clogged nozzles. If the procedure fail, then try again. This happens when you are not using the printer for long periods of time. If cleaning nozzles will not be helpful, then remove the color cartridge from his place and put it with the printing head in warm distilled water for 30 minutes.When the water is coloured by the ink, take the cartridge and touch the printing head with a soft paper towell. If a clear line of colour is printed on the towell, then is OK, put it back in the printer and print a test page. If is not , try again with patience.
Apr 14, 2009 | Office Equipment & Supplies
My hp 915 having trouble printing photos with glosy papers
don't try to put heavy weight paper like 230 gsm in hp 915, it's not a photo printer (MFP), use upto 170-180 gsm only for gears safety, for heavy weight media try another photosmart series printer.
Jan 09, 2009 | HP Compaq Presario 915 (470045-499) PC...
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Epson CX8400 All-In-One InkJet Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
