Question about Motorola Mobility C168i Cellular Phone
My set get water demage how can it's repair and this set is also no any moment voltage are shown on on\off switch and charging voltage are perfectally show but mobile phone is not on. plz short out my problem plz
    Novelist:
  • 152 Answers
Did you dry the phone completely? If not here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Posted on May 21, 2010
What can cause the damage of the infinity g35 brain box
Vibration.... moisture/water intrusion....voltage spike/short.... defective solder joint internally to name a few of the most common
Feb 03, 2016 | Cars & Trucks
Nothing working on my firebird 1991, cooling fans off, charging circuit, w window, heater blowers not working what can this be,
Some of these systems may get voltage from ignition switch? Will it start and run? You may need to check voltage to and from ignition switch. At the moment, I can't rule out the ignition switch as causing a problem, you need to do some testing.
Nov 01, 2015 | Cars & Trucks
Water demage mouth speaker not working how repare?
if you know about mobile repairing .just change the bell of the mobile.
if you dont know you have to send it to a mobile repair store.
May 08, 2011 | Nokia E71 Smartphone
I hv Samsung M-200 and it is water Demaged and in a dead condition so what i do?
Remove the batteries leave it to dry. dont even try to switch it on for 2 days atleast. when you leave it to dry make sure that you are not exposing it to a very high temperature. After it is completely dry use a vacuum cleaner to **** all the remaining moisture, please do not use a blower as it will only send the eater droplets at a further unreachable corner. After doing this try and switch on your phone charge if necessary. do the above to procedures ASAP and give it to a repairing shop if necessary, the sooner the better
May 27, 2010 | Samsung M200 Black OEM GSM Unlocked Cell...
The battery on my 2006 gv250 isn't charging any hints or tips
  • Check to see that water in each cell is above the top of the plates. Add water if needed.
  • Start the bike then check the voltage at the battery terminals with a volt meter. The reading at 1/2 throttle should be around 14 volts. If it is, the battery may have an internal short and will not accept the charge or the battery may simply be worn out. A well cared for battery will usually last about two years.
  • If little or no voltage increase is shown on the volt meter, the voltage regulator, rectifier or stator may be bad. Have them checked by the shop.
Oct 18, 2009 | 2003 Hyosung GV 250 Aquila
Toshiba 32A41 Set comes on goes into shutdown
dear sir it is problem cercuit dry solduring
horizental output is demage. please over all resoldering and change transistor
Aug 28, 2009 | Toshiba 32A41 32" TV
My power distibtion is demaged after power failuure. The power is not reached on on/oof switch because my power supply for start motherboard is demaged after main supply failure. Please send me guide and...
Unplug your power supply from the mother board.
Using a volt meter check for voltage at the plug.
Some power supplies have an internal fuse that
may have blown.The fuse is accessable by removing the cover on the supply(MAKE SURE IT IS UNPLUGED) some times simply changing the fuse will do the trick. if not replace the Power Supply
May 17, 2009 | Intel D865GBF Motherboard
I have samsung refrigerator. There is no water coming out from door dispenser. Ice maker is working absolutely fine. I am looking for some troubleshooting tricks to fix this problem. I have just increased...
hello pungli,
two things. first the water solenoid that controls the water to the dispenser. check it for resistance and presence of voltage when you press the lever to get some water. if there are no resistance, replace the solenoid. if there is resistance and there is voltage, solenoid could have been stuck close. if there is resistance and there is no voltage then the second thing..
second , is the switch that sends voltage to the solenoid valve. when you press the lever, it pushes a switch to send a voltage to the solenoid valve to let water in and comes out at the dispenser. try to check that switch for continuity and on and off as you press the lever.
i hope i was able to solve your problem. please rate me..tnx..
drcool299
Jul 09, 2008 | Samsung Refrigerators
Motorola Mobility C168i Cellular Phone Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
