Question about Panasonic DMR-ES10 DVD Recorder
Panasonic dvr, dvd tray won't open, no button to push with paper clip I hear the motor whirrling, though. Thanks in advance John
  • 1 more comment
  • Anonymous Feb 29, 2008
    Have tried the same. Also with the "up"button and stop at the same time, no button works when power on. Shows "self check" and makes pulsating sounds from disc department. The disc might have been put in upside down, and might also be burned with a neighbours dvd-burner. Never had this problem before. DMR-ES10EP-S serial nr:
    vw5ie002491 bought about 2 years ago, very little used,mostly away, holiday appartment. kind reg Lennart
  • Palmbeach
    Palmbeach May 11, 2010
    If its the DMR-ES10 DVD, turn the unit off, then press the stop button for 5 seconds. Some discs take longer to eject
  • Palmbeach
    MODEL NUMBER?
If you hear the motor whirring then the drive belt may be broken. Pushing the buttons will not work. Someone will have to open it, remove the disc and replace the belt (if it's broken).
Posted on Mar 22, 2008
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
DVD Tray Will Not Come Out
Download updated software for free on Panasonic Website then take a Paper Clip or other small object and insert it in the small hole in front of the machine and manually open the Disk tray. The Updates should take care of the Problem !
Oct 13, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
Hp 6930p the dvd drive is stuck (doesn't open)
Hello gilaz111, to 'open the DVD Drive "Tray."
Look by the {side} of the [Tray].
There is a Pin-hole located right next to the"DVD Eject Button"
The best "Tool" to use is a [Paper Clip] or a 'small object' similar to it.
Place the "Paper Clip" in 'gently' and "Push."
'If all goes well?'
The DVD Tray will open!
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 17, 2011 | HP EliteBook 6930p Notebook PC
My dvd drive won't open.
In the front of the loading tray you will see a small pin hole, get a fine jeweler screwdriver or a needle push in until you hear click the door will pop open allowing access to your cd/dvd disc, if the driver won't work it will probably have to be replaced.
Feb 01, 2011 | Dell Computers & Internet
Got a dvd stuck in my dvd player, dvd is playing but the buttons on the player are not working and don't have open button om my remote control. please help.thx sam
In the front of the Tray of the DVD is a small hole using a paper clip or similar piece of straight stiff wire, insert it into the hole, push in until you hear/feel a click, keep pushing gently and the tray will pop open.
Feb 22, 2010 | Televison & Video
DVD stuck in tray of Panasonic RA60.
many dvd players have a small hole near the tray. if yours has this little hole just straighten out a small paper clip to form a straight piece of wire and insert the wire in the hole. That will open it up for you.
Aug 05, 2009 | Panasonic DVD-RA60 DVD Player
Cyberhome DVR 1600 DVD Recorder
open the cover of dvr, clean the tray or replace the belt
Aug 16, 2007 | Cyberhome DVR 1600 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
