Question about Honeywell HZ780 Oil Filled Radiator Heater
When I plug the heater into the wall it sounds like oil in a pan when it gets to hot, something like a sizzle sound is that normal and safe?
  • 12,061 Answers
NO & NO.
Posted on Jan 30, 2010
I'm driving Kia sorento 2010,there's a sizzling
Depends.
The exhaust is very hot, especially when you stop the engine.
You could be hearing the metal cooling off, or you could be hearing something dripping on the hot pipe. Or melting onto the pipe.
Dec 14, 2012 | Cars & Trucks
97 ford f-250 7.5L orange goo coming out of a round indent near oil pan. the the round indent appears to be on the engine block toward the front of the truck to the left of the oil pan. I have been having...
What you are describing sounds like what's called a freeze-plug. These are round plugs or inserts in the engine that are designed to pop out if the coolant should freeze to avoid cracking the block. the orange goo is rust mixed with coolant. This indicates that the freeze plug is leaking coolant and should be replaced (not a major job).
Sep 01, 2011 | Ford F-250 Cars & Trucks
My fridge works fine but sometimes the freezer will stop working and you can here a sizziling sound coming from the back like water dripping and hitting something hot. I unplug and plug back in and it...
Hello, welcome to FixYa.
This is just the normal operation...specifically the defrost cycle every frost free unit must cycle through every 8-12 hours.
You are correct, the sizzle is water (from the melting ice) dripping onto the defrost heater. It is all normal so no need to worry.
Thank you for choosing FixYa today. Please take a moment to rate your experience here.
Regards,
Macmarkus :)
Aug 15, 2011 | Kitchen Ranges
Traulsen refrigerator drain pan sizzles as the hot water is being evaporated. what can absorb and/or safely deflect this hot water as it hits the pan?
The problem is not in your drain pan, the problem is why is your drain pan getting hot enough to sizzle water as it hits it?
Are there hot spots on the cabinet? That would be a sign that the condenser grill is not able to transfer heat out of the sealed unit compartment. Which could mean a dirty condenser grill or back panel. Are items stored behind the unit that is affecting air flow? Is the compressor fan working and pushing air across the condenser grill and compressor.
Jul 28, 2011 | Refrigerators
Action-Aire AA150 Oil Filled Electric Heater. I am wanting to use this heater but I have two questions: firstly, there are two control buttons (with a light indicator on them) do i need to put on both for...
Oil in these heaters is not supposed to sizzle. So, I don't think it's the oil. Something else is probably making the sizzling noise and that's what concerns me. As this type of heater literally makes no noise. What you hear may be a short in the wiring of the heater. In which case, it's unsafe to use.
You didn't mention if the heater is new or that you've had it for sometime, but in either case, I would recommend not using it. If it's new, then it's still under warranty and you have some recourse. Check your Owners Manual for details on how to handle this as a warranty issue.
Feb 17, 2011 | Action-Aire AA150 Oil Filled Electric...
My lakewood electric heater plug gets hot and starts melting, I have to use a three prong adapter to plug this in..can u help?
Sounds like heat element is defective drawing too much current. Make sure you are not using an extension cord on this heater, it has to be plugged directly into wall socket. Post model number on here so we know what unit we are dealing with.
Oct 09, 2009 | Lakewood Oil-Filled Electric Radiator...
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Honda Civic
just off the wall guess here but sounds like oil filter sending unit in the pan these get cloged with old sitting oil use a solution like warner mystery oil in pan with normal oil this will break down old oil after 500 miles replace oil and do it again for 3 + 500 mile oil changes this will help clean out the old oil
also you might have gotten your plug wires wrong in fireing order
May 15, 2008 | 1997 Honda Civic
Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Feb 13, 2008 | DeLonghi EW0507 Oil Filled Radiator Heater
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
Honeywell HZ780 Oil Filled Radiator Heater Logo
186 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
