Question about Sceptre X32BV-Naga 32 in. LCD TV
Hi...I'm trying to connect my PC to my Sceptre TV but I keep getting an "Out of Range" message. What am I doing wrong? Thanks!
  • Sceptre Master
  • 12,061 Answers
You have your screen resolution is set too high, try a lower one to start say, 640x480 32bit, or 800x600 32bit. Also ensure you have enabled the TV/Monitor & set for Mirrored or spanned desktop? Always plug in the TV and then turn on the laptop.
Posted on Jan 30, 2010
Tv setup - cannot get past auto channel
Connect the TV to the Comcast box using an HDMI cable, then set input on the TV to HDMI - that's all. You then select channels on the Comcast box , not the TV (although the TV remote can be programmed to change channels on the cable box)>
Jan 27, 2014 | Element Televison & Video
Sceptre tv won't turn on after power outage
You may have to open it to see if the line fuse that the power cord goes to is good or bad.
Dec 23, 2012 | Sceptre Televison & Video
I am trying to connect a Sceptre monitor
Will the monitor work on another computer? Will the computer work with a different monitor? Are you connecting the vga port to vga output on the video card or the dvi input to the dvi output on the card. You may need a video card with hdmi output.
Jul 17, 2010 | Sceptre X24WG-NAGA Monitor
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Just purchased aoc tv (L22h998) i am trying to hook up to pc. everything is connected and have it set to pc but it keeps saying out of range...any idea what i'm doing wrong?
when you see that sign, just let it stand for 2 minutes and do not do anything, it is trying to adjust your settings so just be patient, something will come out soon, if nothing comes out after 5 minutes, you have a defective tv.
Nov 27, 2009 | Televison & Video
Connecting pc to grundig32 tv - msg out of range
I am going to suggest with that message, the the TV does not understand the signals it is getting from the PC.
Reboot the laptop while connected to the TV, and turn the TV off, then On, while the PC is connected. If you continue to get the message, look in the manual for the TV to determine the reason for the message.
Jan 23, 2009 | PC Connection FastCAT 5e Patch Cable...
LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Jan 17, 2009 | LG Corbel A- Accessory Range Hood
Sceptre TV Displaying out of Range.
I had the problem on my friends tv.
Switch the cable for the component cables to regular TV rather than HDTV, then start the XBOX
Go all the way to the right blade, and go into display settings. For HD resolution, (don't worry if it warns you you're not in HDTV setting) select 720p, then before it switches back to regular TV settings, go to the cable on the XBOX and switch it to HDTV, and select "Yes, I want to keep this setting." It'll start displaying it right. It's sooo much faster and clearer this way.
I found out it was because the component was set to 1080 setting which I suppose is out of the range of the TV.
Feb 27, 2008 | Televison & Video
PIP function not working
Hi !
I'll have the same problem, but i solve it when i change the RESOLUTION OF THE COMPUTER of 1680x1050 on 1440x900 at 60hz
TRY IT !
Jan 11, 2008 | KWorld 1680 TV BOX HIGH-RESOLUTION...
Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Jan 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X32BV-Naga 32 in. LCD TV Logo
221 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
