Question about Waterco Cover, Skimmer Beige 9 7/8" Oem 51b1017
The hinges on my skimmer box flap have broken need 2 new ones. Can I purchase them without having to buy the whole part.
  • 990 Answers
Depending on what model and brand you may be able to replace the hinge but a replacement will cost less than twenty dollars to get an universal weir all you need to do is measure the throught or bring the old one with you. The new one will have spring loaded hinges that you just pull the pins and the spring will push the hinges into place.
Posted on Jan 30, 2010
I HAVE CHANGED BROKEN FLAP 2 MONTHS AGO BUT THE FUNCTION OF OPERATE SYSTEM AFTER CLOSE THE FLAP CANT WORK PROPERLY, SO PLEASE TELL ME WHAT CAN I DO?
Was the flap changed by a techician ?
I have played with my 1200 and thus
know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Good Luck.
fixya[at]technife[dot]com
Nov 05, 2010 | Motorola Mobility A1200
I presently have a Hayward EC 60 (yes 60) pool filter and a 1 horse power motor.. It works well but it does not support the new Pool Vac cleaning robot I purchased. It supported my old Pool Vac, but not...
if you buy an adaptor,should be a 1 1/2" dia hole,in the bottom of the skimmer, put it in the skimmer hole,put your vac line on that, turn the valve to it's on full skimmer, it will work,
thats a nice filter,pool guys will sell you anything!
esp at this time of year!
buy the minumum!
Sep 13, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have a 3/4 hp superpump that is about 2 mos old. when it runs it "Surges" and puts out no pressure. The suction line is drawing in water.
I had a problem with mine. It also was drawing in water but it turned out it wasn't enough. The flap on the skimmer wasn't opening all the way. It get stuck closed sometimes. I probably need to sand on the hinges a little.
Aug 27, 2010 | Hayward SAND FILTER, PRO SERIES
I have a 2005 Nissan Murano, when the AC or Heater is running it smells like ****. Any solutions?
Yes you need to change your in cabin filter. Wal-mart sells them for around 15$ if you buy the one from Nissan it is around 50$. You will find many recommendations for self install that say to take apart the dashboard and 7 or so screws. Skip that the easier solution is to slide out 2 hinge pins that hold the glove box in place they are located on the underside of the glove box. You will find there is a string that holds the detached glove box so don't yank too hard once the hinge pins are out. Support it if possible so it's not dangling in mid air. There are some clips that cover the flap that holds the filter in place a flat screw driver will make prying those easier. Note orientation on uninstall of old and reverse procedure with new filter. Reinstall flaps/clips then glove box. Viola Saved yourself 129$ dealer install..
Oct 14, 2009 | 2005 Nissan Murano
Collection grid
You can purchase a new collection grid on ebay.
Jun 25, 2009 | Sharper Image Professional Plus Ionic...
Ds lite hinge is broken is there an easy fix Right Hinge Broke, Screen Flaps instead of clicking and occasionally goes blank.
beeabe,
I'm sorry to tell you but there is no *easy* fix. If you've had no experience taking apart and assembling a Nintendo DS, I advise you NOT to start with your one and only. It's so easy to rip the LCD cables because they're so thin and you'll have to go buy another.
There are two ways to fix this... Super glue / tape it as much as you can , or send it in for repair or find a local Game repair place.
To fix a broken hinge on a DS, it requires you to disassemble the WHOLE thing. Which sucks when just starting out.
May 30, 2009 | Nintendo DS Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Housing dispenser broken at ice flap
Yes this is a common problem.  However, you don't have to replace the whole door.  They were wrong.  Whirlpool makes a fix kit for this.  You can get it at http://www3.sears.com/.  The part # is 8201649 and cost is $42.99.  The description will say door chute.  It is a door mechanism assembly.  It is fairly easy to install and comes with instructions.  Hope this helps.
Oct 25, 2007 | Whirlpool ED5VHGXM Side by Side...
Waterco Cover, Skimmer Beige 9 7/8" Oem 51b1017 Logo
528 people viewed this question
Top Waterco Garden Experts
Dennis Key
Dennis Key
john h
Are you a Waterco Garden Expert? Answer questions, earn points and help others
