Question about Kenmore 46462 Front Load Washer
F 21 fault ?? on a kenmore mod 110.47512601
Whats a F 21 fault ?? on a kenmore mod 110.47512601
How do you fix?
    President:
  • 1,314 Answers
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Posted on Feb 18, 2008
  • keoneasai Jan 11, 2011
    awesome! called sears and it would have cost me $129 for a trip out parts and $219 for a annual warrenty and they wouldn't let me talk to a tech for help with out warrenty. You da man! When ever something goes wrong for the first time in four years or so by that time your warrenties up. thank god for the internet and thank god for you guys.......!
I have a Kenmore upright freezer there is ice built up along the top and upper/lower shelfs what could be the problem
Ice build up is usually a tell-tell sign of a defrost related problem.
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts
Jan 29, 2017 | Kenmore Refrigerators
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
I have a kenmore HE-21 front load washer. I am getting an error code F 21?
It usually indicates a clogged drain filter or pump. Here is a link that should help F21 Fault Code Repair
Dec 28, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 832 front loader wont spin f 21 comes up what does that mean
It usually means the drain filter is clogged up. Try this link
Dec 20, 2010 | Washing Machines
Kenmore Range Mod # 911.4652191 Getting error code F1. What is wrong with the range
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 25, 2010 | Kenmore Kitchen Ranges
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
Paper motion fault on mannesmann tally mt661
Clean dust off sensor
Enter tech mod via cntl panel
select re-cal
job Done ( Ex mannesmann tally Eng 21 Years )
Aug 12, 2009 | Office Equipment & Supplies
Kenmore 46462 Front Load Washer Logo
207 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
