Question about Saeco Incanto Classic Espresso Machine
My incanto rapid steam wont prime. the red light continues to flash. I turn on the hot water light and it will dispense some water but it is not hot and this only lasts for a5 or so seconds. I can't then revert to steam. It broke down when i was steaming some milk.
  • cutten Jan 30, 2010
    I assume this is the hot water knob. This didn't work.
    President:
  • 2,501 Answers
I have investigated this machine on the internet and experienced users reinforced my original opinion that the machine needs cleaning.
One user who had used several of these machine professionally, said that frequent cleaning was essential. Once a month would be reasonable for the machine.
Posted on Feb 04, 2010
    President:
  • 1,618 Answers
Try this push in on the knob after it releases the 5 secs of water, if that works, then the steam tap assemble needs to be replaced.
Posted on Jan 30, 2010
  • Ernest R
    Ernest R Jan 31, 2010
    Check the booster steam boiler and make sure the thermostat did not trip.
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
Sep 27, 2014 | Saeco Odea Giro Plus Coffee Maker
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
Hi, I a problem with my Saeco s-class incanto classic coffee machine. The two coffee cup lights are flashing green the water light is flashing red. I prime by turning the steam valve and hardly any water...
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
Aug 29, 2010 | Saeco Incanto Classic Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Machine won't prime
Try lifting the water tank, then setting it back in place, and then priming the machine.
Jan 15, 2010 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
318 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
