Question about Equator EZ 3710 CEE / W Ventless Washer/Dryer Combination
Broken heater during the dryer cycle
Hello, My equator ez 3710 washer dryer does not have any heat during the dry cycle. The dryer tumbles, but there is no heat, and therefore the clothes do not dry. How can I fix this?
  • Anonymous Mar 16, 2014
    Dryer doesn't dry the clothes. I think it's plugged with lint. How do I get the lint plug out?
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Can I have my broken door fixed?
A door clip don't cost much go to an appliance parts dealer & pick one up. If you can't put it on find someone to put it on for you. Not hard at all.
May 19, 2014 | Equator EZ 3720 CEE / P Washer and Dryer...
Burns clothes!
http://www.fixya.com/WrnModule.aspx?prdid=42469
cheak this out once
Feb 08, 2008 | Equator EZ 1500 Front Load Washer / Dryer
Wont final spin
Most likely a door pin switch problem. The machine is sensing the door is open even if it may be closed.
The switch could be cracked or broken and needs to be replaced.
Mar 13, 2010 | Equator EZ 3710 CEE / W Ventless...
Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Combo Washer-dryer
Just for your information, you can call Appliance Desk and speak to their technical support to understand the wiring diagram.
You can download the manuals from their website as well which www.appliancedesk.com
Jun 29, 2008 | Equator EZ 3710 CEE / W Ventless...
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Equator ez3710 not working
call a repair man or somebody like that and they will fix it....trust me...it happened to me before!!!! :) ♥ your friend wizzz
Nov 09, 2007 | Equator EZ 3710 CEE / W Ventless...
Black marks
throw a clean pair of old sneakers in the dryer with the clothes. this should not allow the clothes to stay in one place during the entire dry cycle
May 25, 2007 | Equator EZ 3612 CEE Front Load...
Washing Machines Logo
321 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
