Question about IBM ThinkPad T30 2366 Notebook
No display in ibm thinkpad laptops i check battery mode ,power , ram replaced, bios clear ,processor heat sink removed apply paste and refix and i used external monitor also but no display .
    President:
  • 2,017 Answers
You tried all the possible way i think problem with mainboard i advised you to show it service center.
Posted on Jan 30, 2010
No post
This sounds like it could be an overheating issue. Some manufacturers use a cheap thermal paste on their processors. If you are dealing with a computer this should be an easy fix but if you are dealing with a laptop then it is much more involved. Go to Youtube and research replacing or removing heat sink. You wont be replacing the heat sink but the procedure is the same except you will need to clean the old paste off your heat sink before you apply more. Don't go crazy with the paste, a little goes a long way, all you are doing with the thermal paste is ensuring full contact between the processor and the heat sink with no air gaps.
Feb 28, 2013 | Dell Studio 1558 Notebook
Tip
REMOVE BIOS AND POWER ON PASSWORD ON THINKPAD LAPTOPS
THINKPAD BIOS AND POWER ON PASSWORD
The BIOS password is configured from the BIOS setup and this password is stored on a 20RF08 EEPROM chip. There is no backdoor password available and IBM/Lenevo support says the motherboard needs to be replaced. Also removing the BIOS battery to discharge the BIOS and reset it to the default settings will not allow you to bypass this password.
This also applies to the Power On Password and the Hard Disk Password.
There is a way to crack the password but you need electronic skills, electronic components and several programs plus a working computer to carry out this task.
For details on how to do this, check out this WEB site.
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
on Mar 14, 2010 | Computers & Internet
IBM x3400 server hanging / chipset & processor heating, but cooling fans are working properly.
Make sure that the fans are working at proper speed (not stuck or slow).
Secondly, heat sink could be clogged due to dust or not properly seated. Clean it if required. You may remove it, clean its fins and replace it back (for both processors if required) . Don't forget to apply THERMAL PASTE between the heat sink and the processor (If you remove the heat sink). The Thermal paste conduct the heat from the processor to heat sink which is then dissipated into air by the processor fan. You may also consider adding an additional fan, if required.
Also, place the PC at a well ventilated location so that the cool air enters it from the front and warm air leaves from the back.
Sep 26, 2011 | IBM x3400 Server
IBM R51 laptop when start the laptop it canot boot and error display thermal sensing error
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 05, 2011 | IBM ThinkPad R51 Notebook
Battery charged ok but mashine not start
Hello nt06,
The reason for the machine failing to power up may be caused by several factors:
1. Poorly seated RAM banks: To solve this problem, open up the rear undercover of the unit and access the memory banks.Carefully remove the SODIMM RAM banks and reseat them again. 2. Failing CPU cooling fan or worn-out heat sink and CPU thermal paste: In some cases, especially with old laptops, the fan may fail due to too much clogged dust making the CPU to attain the T.MAX Junction temperature(100) before it boots, forcing it to halt.If this is the case, carefully clean and blow the ventilation slots, open up your notebook and confirm if the fan can run.If the motor's damaged, replace it at a locla technicians. You may also need to re-apply thermal paste between CPU and heat-sink.In this case, I suggest that you use AC-5(Acrylic Silver 5 thermal paste flux). 3. A poorly configured RFID BIOS Area, causing the SMBus(System management bus) controller to fail. You can solve this problem by accessing the CMOS reset button/jumper on motherboard.This will clear all the BIOS setup data and revert to default BIOS configuration. You can also reset the SMBus controller directly by grounding the screws under the battery, if supported.
I hope that solves your problem.
Feb 09, 2011 | ASUS Z96Jm Laptop Charger...
I have a ibm thinkpad when i hit the power button the lights come and the fan kick on but then it shuts down
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for any further assistance u may plz leave comment and or testimonials at any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 23, 2009 | IBM ThinkPad T42p Notebook
Year old advent netbook 4211b will not turn on,
When you press power button press F1 or F2 or "del" key if you can see bios screen then you not need to refix RAM memory or reset bios.
IF you can see bios screen then lake sure harddisk is detected and SATA is disable then save settings and exit.
Also when you power up press F8 key if you able to see safe mode and other menu then you have change screen resolution enter in enable vga mode.
Then open control panel and display then change scree resolution to 1024*768.
Then apply and ok.
But if you can't see bios screen or nothing in dispaly then you have to refix RAM memory .
Check in back side there is 1 plate open it then refix RAM memory.
If still not get display then open back cover of laptop then find motherbord on it then pull cmos cell for 10 minutes so all settings go to defaults then again refix cmos cell then check.
Let me know if you need more assistance.
Thanks.
Oct 08, 2009 | Advent Netbook
Thinkpad R40e has no display
Dear Sir,
According to your post it seems to be a deffinately problem with RAM.Just Remove the below small panel where RAM is located (you can identify the panel at which where small curved indication showing RAM exisitance beneath that panel)Remove the RAM clean it twice and reinstall it in same place.Now turn on the laptop deffinately your laptop shows display. If it is not check with another RAM.This solution deffinately helps to solve your problem.If you have any query come back with more information.
good luck
Fixya Customer Support
Chandrashekahr
Jul 29, 2009 | IBM ThinkPad R40 2681
Power Button wont do anything
First check your num lock key on key bord if it is on off when you press num lick key then your dispaly is working fine means you need to change screen resolution.
For that when you power up the computer press F8 key then enter in enable vga mode.then go to display property and change screen resolution to 1024*768 or 800 *600.
Also when you power up the computer press F1 or F2 or 'del" key to enter in bios then load optimal defaults also check your harddisk is detected .Disable your satat option in bios .then save settings then check.
I f you not able to enter in bios then Refix your ram.If still face problem you need to reset bios .
For that you have to open laptop cover in back then pull cmos cell from mother bord for 5 minutes then refix it then check.
Jul 27, 2009 | IBM ThinkPad T60 Notebook
IBM thinkpad T21
I had a similar problem after My pc got damp in a bag in the rain. I contacted IBM and was given this fix which I am supprised worked but it did so here it is cannot hurt to try. Remove the main battery and the mains power supply press the power on button for 17 seconds. This I think is to drain all the power from the laptop altogether. Replace the mains lead and turn on. Once the laptop has openen up into windows turn it off and replace the mains battery then power on again. In my case this worked I hope this helps.
Oct 17, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad T30 2366 Notebook Logo
126 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
