Question about Philips HTS3410D/37 700W DVD Home Theater System System
Everythihg was working fine for 18 month then it wouldn't power up. checked outlet & confirmed power at outlet. ???
  • bcam07 Jan 30, 2010
    Thank you
  • 11,896 Answers
Most likely you have the common power supply aka high voltage transformer failure. Especially in newer tv's. Parts are made cheaper and faster. If you have a fuse in there, take a look at it, if blown, replace it. If it's good or you don't see one, Then I would put my bet on bad supply/transformer.
Posted on Jan 30, 2010
  • Nate Stansfield
    Nate Stansfield Jan 31, 2010
    Not a problem! Thank YOU!
My Panasonic PT-50LC13 HDTV won't turn on. No blinking lights, nothing. Was working fine a couple of hours before and only unplugged it to move it to a different table a couple feet away. Hasn't worked...
Did you use a new electrical outlet? If so, have you confirmed the new outlet has power?
Did you try moving the TV back to the original outlet and confirm the TV will not power up?
Apr 05, 2018 | Panasonic Televison & Video
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
My dishwasher (Model # FDB520RHB0) is not quite 2 years old. We had the water pump replaced a few months ago because it had been making a grinding noise. Then we tried to run it a few days ago and it...
Did you check the outlet with a voltmeter? If you did and have 120Volts then it sounds like your latch switch could be defective which would kill the power to the unit.
But remember that in most houses that the outlet under the sink is wired for a garbage disposal where the top outlet is controled by a switch and the bottom one is wired for the dishwasher.
Jul 27, 2011 | Frigidaire FDB520RH Builtin Dishwasher
I was cooking food for 1 minute and it just shut off after approx. 30 sec. There are no lights or power now. The outlet is fine. The unit is 4 yrs old.
Check your other appliance. You may have tripped a break. If they are all functioning, and you have no dead outlets in your kitchen, then the unit will need to be serviced. Hope it's the breaker.
a 1200w microware will draw 10 amps all by itself. Your outlets are most likely on 15 amp breakers, so it wouldn't take much amp draw from another kitchen appliance to trip the breaker.
May 11, 2011 | Dacor DMT2420SS Microwave Oven
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Maytag MGR series double oven gas burner trips GFI outlet. There is no direct shorts. Would work when bypassed GFI. but not for long. Now nothing and gfi replaced. Stove fried last one. Stove running for...
the manufacturer recommends a 15 amp time delay breaker or fuse. Which means to me that a GFI outlet will not work on this unit. most of the time it just causes more problems than it is worth? I would only use those type of outlets if code required it.
Dec 18, 2009 | Maytag Kitchen Ranges
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Power accessory outlet for 2005 Honda CRV
I have (had) a 2006 CR-V with the same problem. The identified fuse for the outlet (#18) was not blown. However, there is a fuse identified as "+BR ACC" (fuse #15) that was blown. Both are 15AMP fuses located in the fuse box under the steering column. Replaced the #15 fuse and the outlet is working just fine.
Mar 09, 2008 | Car Audio & Video
155 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
