Question about Whirlpool Calypso GVW9959K Top Load Washer
My washer makes a buzzing sound but does not spin or pump water out
Washer buzzes and nolonger spins or pumps the water out of the washer. Flashed a FL code?
    Sniper:
  • 65 Answers
Fl is the code for a pump takind too long to drain. you have the buzzing so hopefull it is just clogged with small sock or debris from a yarn type item. to access pump (there are two types) unplug washer if you can bring it outside as this can hold lots of water. if not have a large wet vac handy. tilt washer 45 degrees to access bottom panel . remove three 5/16 screws, remove panel. the pump has one beige hose,one black. unclip or remove 4 torx screws depending on the type pump. clear pump. re-assemble. if indoors very important to slowly remove beige hose while running vacuum if not several gals of water will rush out. if this is a pump with the grey housing and it occurs immediately you have probably stripped the pump shaft and will have to replace it with the newre style pump. which will be the same procedure just one more step. the pump retails about 88 dollars. good luck
Posted on Feb 18, 2008
My washer won't spin, just makes a buzzing sound is this repairable?
fl is the code for a pump takind too long to drain. you have the buzzing so hopefull it is just clogged with small sock or debris from a yarn type item. to access pump (there are two types) unplug washer if you can bring it outside as this can hold lots of water. if not have a large wet vac handy. tilt washer 45 degrees to access bottom panel . remove three 5/16 screws, remove panel. the pump has one beige hose,one black. unclip or remove 4 torx screws depending on the type pump. clear pump. re-assemble. if indoors very important to slowly remove beige hose while running vacuum if not several gals of water will rush out. if this is a pump with the grey housing and it occurs immediately you have probably stripped the pump shaft and will have to replace it with the newre style pump. which will be the same procedure just one more step. the pump retails about 88 dollars. good luck
Nov 26, 2012 | Whirlpool Washing Machines
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Jan 12, 2010 | Whirlpool Washing Machines
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
171 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
