Question about Husqvarna Sewing Machines
How to thread a viking husqvarna model 6010 - Husqvarna Sewing Machines
  • 52 Answers
SOURCE: Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
Posted on Jul 14, 2009
SOURCE: Husqvarna Viking Designer 1 Beeper
when i,m doing a machine embrody the thread will fray in the needle and spoil the whole design, i,m afaird to do anything on a piece to keep. what is the best thread to use
Posted on Feb 14, 2008
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
The plastic gear in the 6010 Viking is cracked and I'd like to replace it.
Have you searched the internet?
Absolute Sewing Machine Information Husqvarna Viking Service manual
Sewing Machine Viking 6000 Cam Replacement (not sure if it is the cam gear that needs replacement)
If you are unable to find instructions, perhaps you can find an independent sewing machine repair person who would be willing to do it for you.
Jun 03, 2016 | Husqvarna Sewing Machines
Need to know how to take the cover off of a viking 400 sewing machine?
Screws are either T10 or T20. There are some on the back and some on the bottom. However, would recommend taking it to a Viking Service Tech for repair. Occasionally you can use tweezers and pull thread out if it is not tightly embedded in the sewing head. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Aug 18, 2014 | Husqvarna Viking 1
Hi, my name is Silvia, I 'm from Argentina and I inherited a husqvarna 2000 (model 6010) from my grandmother and i don't know how to thread it. I need the manual for the sewing machine, I'm looking for...
Hi Silvia, i can try to email it to you, but it might be too big a file, in which case i could put it on a cd and mail it to you if you can just cover cost of cd and mail.
cheers
Lisa
Oct 25, 2010 | Husqvarna Viking 1
Need handwheel for viking 6010
check with huskavarna viking they can put you in touch with a dealer
check on ebay
Jul 29, 2010 | Husqvarna Viking 1
How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
Need to buy spare part: Thread take up lever for Husqvarna Viking Model 6020. Traveled on airplane and inspectors broke my machine!
start trying viking dealers or ebay this machine is no longer supported by viking and is NLA on all parts so your best bet is a dealer that might have a junk one for scrap parts
Jun 10, 2009 | Husqvarna Viking 1
Someone gave me a machine
Kelly,
I found the Instruction Manual for the 6000 Series machines (6010 and 6020) on www.sewusa.com available for purchase: $15 including shipping.
Additionally, the site says they will post a FREE Threading Diagram for any machine for which they have the manual. You need only make the request through their email link on that site. They already have posted Threading Diagrams for several Viking machines, however the 6020 is not yet posted. I emailed a request tonight. Hopefully they will get it posted soon.
Let me know if there's anything more I can do to help.
~Alkara
Mar 11, 2008 | Husqvarna Viking 1
Sewing Machines Logo
474 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
