Question about Refrigerators
No water going to ice maker. Ice maker is calling for water. 10 volts on plug voltage does not change when I hear it turn on
  • 3,740 Answers
Hi. Sounds as if you are some what familiar with using a meter for testing circuits. Disconnect at least one lead from the water valve coil and Read across the coil checking for resistance. I should read less than 10 Ohms.
From what I read about you only having 10 volts you have a voltage issue as the coil voltage should read in this range 115 / 120 VAC. The 120 VAC is controlled by an actuation arm that is actuated by a cam lobe inside the icemaker front cover. If the actuating arm is bent or broken the icemaker will cycle but the water valve will never be activated with 120VAC to energize the coil for the duration of the icemaker fill cycle.
If your up to it you can make your own test cord from an old extension or power cord with two female bayonet terminal ends and verify the water valve operation.
Connect the locally made by you test cord female terminals to the water valve and BRIEFLY plug in the cord. The water valve should open when you plug in the cord and shut off when you unplug the test cord.
Posted on Jan 30, 2010
KENMORE 106.53644300 ice maker type 2 with front door dispenser. ice maker stopped making ice, than 3 days later started again then stoped, day or so later ran again then stopped. I removed the unit put...
That is a Whirlpool module type ice maker that seems to have has been so strict with their information I will need to give the manual's another way about a 5 year life span. I have some manuals but because Whirlpool stopped letting people post what they believe is their property. I guess I need to only understand but if I place them here I will lose my subscription. Click Here=> My E-Mail and I will send it to you. May have to fill out the capsha first. Below is what I am talking about as far as how they work and yes I have the schematics and tech sheets, I will look to hear from you, Thanks, Sea Breeze
Click Here=> 8201515 Ice Maker Module
May 05, 2011 | Kenmore Refrigerators
Ice maker quit making ice. What could it be?
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold. Confused yet? LOL
Nov 13, 2009 | Maytag MSD2651 HE Side by Side...
No ice or water coming from fridge door
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker does not work. The water dispenser works, but not the ice maker
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold. Confused yet? LOL
Nov 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Oue Kenmore Coldspot ice-maker quit working. Any
Nov 11, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker doesn't work on whirlpool gd5rhaxnb00. indoor dispenser for ice and water - water works but doesn't produce ice.
Nov 11, 2009 | Whirlpool GD5SHAX Side by Side...
Ice Cube Maker
Nov 11, 2009 | Refrigerators
The icemaker will not dispence ice
Nov 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker and water dispenser not working. it makes a funny girgling noise when water is "filling" for ice machine
Nov 10, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker stopped working
If you manually advance the ice and when the ejector blade reaches 10 oclock that when it calls for water. You should hear the valve come on. If not it could be a bad water valve. Part#2552A or you might want to doublecheck to see if your getting voltage there when the blade reaches 10 oclock. If no voltage then the water switch is bad.
Jul 19, 2009 | U-Line Icemaker
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
