Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Oven enamel chipping
Has anyone had problems with the enamel deteriorating and falling off on the inside of the oven? If so, how did you go about getting it repaired or replaced? I have a Dacor RSD30 Dual Fuel stove and the enamel is falling off the inner facing of the oven. It is 4 years old and I rarely use the oven. Any assistance would be appreciated. Thanks Having the same problem with our Dacor ERD30 dual fuel. Enamel is chipping on the bottom of the oven. It is 4 years old. Dacor has already replaced our dishwasher out of warranty, so they will be getting a phone call from me on Tuesday for sure. A $3400 oven should not do this - period. Anybody have a solution yet?
  • bakerjung Feb 18, 2008
    I have the same chipping also. My first dacor RDS 30 chipped after 2years. It was under warranty so Dacor gave me a new one. Now after 4 years on the second one the enamel is chipping too.
  • Dane Harr
    Dane Harr Apr 05, 2017
    This is a quality issue with Dacor. Baked on enamel finishes when properly applied should last longer than a lifetime. You need to insist on a warranty replacement. Have them explain how a 300 dollar Hotpoint Range can outlast the enamel finish on your Dacor. They won't have a respective answer.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Posted on Apr 06, 2017
    Top Expert:
  • Dacor Master
  • 81,400 Answers
Never heard of such a problem, you are the first to post it. There is no fix for this.
Posted on Apr 05, 2017
Rotu
  • 175 Answers
SOURCE: Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Posted on Jan 13, 2007
KOakaKO
  • 135 Answers
SOURCE: Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Posted on Aug 13, 2007
  • 100 Answers
SOURCE: Dacor oven will no heat.
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
Posted on Nov 03, 2007
  • 131 Answers
SOURCE: Replace RSD30 oven control
This is one of the hardest stoves to get into. Turn off the breaker.
Pull off the burner knobs. This should reveal four large plastic nuts holding the console in place. You can turn them gently with channel locks straight on - not from the side. After you've got the console loose, everything else is downhill. There's lots of screws behind console, and across the bottom of the console (just above the door.) Remove just the ones you need, or face the wrath of Dacor!
Be careful about the rubber strip across the top of the console. It often stretches during a repair. You might have to cut off 1/4 to 1/2 in to get it to fit again.
The large plastic nuts are very east to get cross threaded when replacing them. I recommend turning them counterclockwise until you can feel the threads line up.
Posted on Mar 11, 2008
maklean
  • 1665 Answers
SOURCE: Dacor ERD30 oven trouble
You must inspect all switch contacts, wire continuity, and connections to be ok.
Posted on Mar 25, 2008
How to fix enamel chips on bottom of Dutch pot
Hello, John -
You do not state if the chipped enamel is on the interior bottom or the exterior bottom of the Dutch oven.
Read the comments about chipped enamel on a Dutch oven here:
https://www.chowhound.com/post/repairing-surfacing-enamel-coated-cast-iron-766196?page=2
I have found advice stating an enamel chip can be repaired by using a food grade enamel repair kit. However, all the information I have found indicates that a "food grade enamel repair kit" cannot be found for purchase. Sigh . . .
If your Dutch oven is a Martha Steward brand, read this:
https://simpledailyrecipes.com/11956/what-to-do-when-your-martha-stewart-enamel-cast-iron-dutch-oven-is-chipped/
If your Dutch oven is a Le Creuset and is cast iron with an enamel coating, it may have a lifetime warranty, if you are the original owner. Read the warranty details here:
https://www.lecreuset.com/warranty#ci-warrantytime
Choose "Cast Iron" and "Submit a Warranty Claim".
Best wishes.
Mar 16, 2018 | Home
My oven has the blue enamel inside and I want to clean it. I read that the self cleaning mode can chip the blue enamel. Also I know that I should not use oven cleaner. What is the best method for...
Sorry to read about your problem, I hope this helps you out.
use regular oven cleaner, if you wish
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | KitchenAid KEBC208 Electric Double Oven
A plastic plate was put by mistake into our oven. It melted all over the bottom enamel. Trying to get this off with a knife and a razor blade has chipped some of the enamel. Can this be repaired .....
IM NOT SURE ABOUT THE TOXICITY BUT IF YOU HEAT UP THE OVEN AND WITH A GLOVE ON HAND AND A PUTTY KNIFE YOU SHOULD BE ABLE TO REMOVE MOST OF IT. THEN MAYBE RUN A SELF CLEAN CYCLE WHEN YOU CAN OPEN THE WINDOWS AND REMOVE ANY SMALL CHILDREN FROM THE HOUSE.OTHER THAN THAT THE SPOT YOU REMOVED THE ENAMEL YOU MAY USE A BBQ GRILL PAINT TO COVER THE METAL OR JUST LEAVE IT.GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 07, 2010 | Kitchen Ranges
Flash in oven
The flash is usually caused by metal either being placed inside of micro or the interior surface might have chipped enamel exposing the metal underneath. Make sure no metal materials are placed inside while using and that the interior surface is in good condition.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
I just noticed that the oven enamel is chipped in a few places where the racks sit. Do I need to replace the oven?
At this moment in time, there is no need to replace oven, it is quite o/k to carry on using it.
Please rate my solution.
Thanks.
Sep 19, 2009 | Ovens
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Metal turntable's enamel chipped, so sparks fly.
Try Going To Your Local Hardware Store And Finding Enamel Repair.
It May Just Cook But I Hope It Doesn't.
Jan 05, 2009 | Sharp R-820B Convection/Microwave Oven
How best to clean neff U1320 oven
The door itself is vitrous enamel, although I have not found it a problem if some gets on to it.
What you must ensure is that you do not put any on the element liners or covers on the sides. of the oven, otherwise it stains them.
Don't get it on any paint work either.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Ovens
Enamel chipping
the interior of the oven cavity is chipping??? if so not a worry or concern for saftey or health concerns stictly cosemetic
Nov 12, 2008 | Ovens
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,210 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
