Question about Samsung WF337AA Front Load Washer
I am getting d6 error message on my samsung washing machine it happens half way of the quick wash cycle can you help thanx
SOURCE: samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Posted on Feb 15, 2008
SOURCE: washing machine
verifica si tienes suministro de h2o dela red, luego verifica el funcionamiento de las electrovalvulas ( deben medir alrededor de 800 ohmios) ) y por ultimo verificar que esten siendo alimentadas por la tarjeta de control, si no esxiste alimentacion , verificar el estado de la tarjeta de control.
Posted on Jul 09, 2007
SOURCE: beko AA class washing machine 1000rpm WMA 510W
If you search on the Beko website, you can download manuals for their machines (including the 510W).
Posted on Apr 24, 2008
IFIXALL
  • 868 Answers
SOURCE: Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Posted on Jul 13, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    E20 error message
    maybe you should just get a new washing machine
    Dec 11, 2013 | Washing Machines
    2008 Samsung front end loader develops a 4E error
    When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
    1. Turn off the water source to the washing machine.
    2. Unscrew the hose from the back of the washing machine.
    3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
    4. Push the filter back into place.
    5. Screw the hose back onto the washing machine.
    6. Turn on the faucet and make sure the connections are watertight.
    Also, please check the following:
    • Make sure the source water faucet is turned on.
    • Check the water pressure.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
    Jul 12, 2010 | Samsung WF337AA Front Load Washer
    Samsung J1455AV: Washing cycle does not complete and then stops
    go back to where you bought it and have the engineer look at it might have been faulty when bought.
    Jul 07, 2009 | Samsung WF337AA Front Load Washer
    Keeps flashing SE
    I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
    Mar 30, 2009 | Samsung Washing Machines
    Samsung WD-J1255 Front loader Washer/dryer combo
    I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
    Nov 01, 2008 | Washing Machines
    F-21
    replace the contol board
    Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Error with 'Debris Filter' on Samsung WD-J1255 machine
    remove pump and dismantled it,I don't think the rubber you found is off the machine,look for something caught in pump
    Mar 21, 2008 | Washing Machines
    Zanussi progress 1200 WASHER DRYER
    This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
    Dec 26, 2007 | Washing Machines
    Samsung WF337AA Front Load Washer Logo
    216 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
