Question about RCA M4208 MP3 Player
When i turn my mp3 player on, it freezes at the "initializing" screen. when i used the RCA software to update the firmware, it installed, but there was an error saying RCA must close.
  • 11,896 Answers
There are several ways in which you can unfreeze your MP3 player When you player freezes, it will only start up and not play the songs or even the buttons won't respond to your pressing them, it is more like your computer hanging and never coming back to working fine unless you restart it. The first thing you should try to do is read the instruction manual and check where the reset button in your MP3 player is. Take a small pin and push the reset button. This will make you player go off for and then you can put it on again and it will work fine. However, there is a possibility of data loss when you reset. Most of your stored stuff will be gone after reset. Another thing that you can do to retrieve your player is doing a firmware update. Do a refresh of your firmware and see if it works, in most cases, it does.
You can also take it apart, remove the battery, press and hold power button for 5 full long seconds, reinsert and turn it on again.
Posted on Jan 30, 2010
Player will not initial stays on initializing
Sounds like there is an issue with the firmware. Download the firmware install from here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds. If that does not work then it is likely the player is unrecoverable.
Oct 29, 2009 | RCA M4204 MP3 Player
RCA Opal 8 gb mp3 player stuck in initializing mode
I had this problem. I had to really try several different things to get the software to recognize the mp3 player. RCA does have download software that will format your MP3 player and put the firmware on the player. It would be better to get the firmware on without formatting if you have files already on it. Just be sure that you get the screen that shows it is connected to USB.
Jan 21, 2009 | RCA OPAL M4001 MP3 Player
My RCA Opal again...
I had the same problem too. I was about to give up and throw this RCA player away but I it is only 5 weeks old, I got it for christmas and would feel terrible letting it go because of this stupid problem. I noticed soo many other people had this same problem, and since I spend over an hour and got it fixed, I had to share my solution and hopefully help others. I must have tried bwelliver's solution 10 to 20 times before I finally figured out the pattern to doing it. Unfortunately, i should have gone down and noticed what clklause has recommended, which was to ensure that the power is turned off before plugging in the RCA mp3 player.
All I did was download the firmware from the link that bwelliver linked to, unplugged and turned off my RCA M4208GR-8 player, then 1) I ran the firmware software 2) held down the Play(center button) on the RCA mp3 player that the power is still TURNED OFF, and 3) plugged in the player to the USB plug right after starting the firmware program. I watched the firmware program on the screen and noticed it would go from "searching" to "initializing" and I immediately released the Play(center button) on the RCA player and sure enough, the RCA player would begin initializing, and I was able to click Start on the Firmware program from the PC.
Hope this helps
Jan 17, 2009 | RCA M4204 MP3 Player
Turn on, won't go past initializing
IF the mp3 is stuck on initializing your firmware went bad.
You need to go to the RCA website.
http://www.rcaaudiovideo.com/
search your make and model.
download the firmware for it.
After the firmware is download
plug mp3 player in usb device of your computer.
Then install the firmware.
Jan 16, 2009 | RCA OPAL M4001 MP3 Player
Mp3 player freezes at initializing screen
Plug it into the usb device.
Hold down the power button for 10-15 seconds.
Go to the RCA website download the latest firmware and install it.
That fixed mine and a few other people I know that have one.
Jan 09, 2009 | RCA M4204 MP3 Player
My rca opal mp3 player freezes on the screen where it says initializing when i turn it on?
Go to "http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2559"
To update the firmware of the M42xx mp3 player click here and download the firmware. start the firmware and when it is runnin plug the M42xx in at the same time holding down the PLAY BUTTON (center) until a white screen with a small computer with a line going to your M42xx is displayed and then release the PLAY button. You can then click on start and the firmware update will complete,,, DO NOT DISCONNECT DURING THIS UPDATE... it may take 2 times to complete this but it will work.... YEA!!!! WORKS with 2, 4 or 8 GB Models.....
Jan 01, 2009 | RCA M4204 MP3 Player
Firmware update froze my mp3
mine froze on that too but I just reset it and it turned on fine the next time. also does it connect to the pc. if it does you can reinstall the firmware through easy rip
Dec 29, 2008 | RCA M4208 MP3 Player
CARL
Nov 07, 2008 | RCA M4204 MP3 Player
RCA Opal Initializing Problem
Just got to the RCA website.
Then hook you mp3 player to usb device of your computer.
After mp3 is hooked to computer
Install the newly downloaded firmware.
Oct 24, 2008 | RCA OPAL M4001 MP3 Player
Frozen on gogear screen
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 27, 2008 | Philips GOGEAR SA6045 MP3 Player
RCA M4208  MP3 Player Logo
150 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
