I plug in the usb receiver into usb port and i hit the power button and nothing happens. i'm running windows 7
    President:
  • 2,022 Answers
Press the connect button also on mouse and keyboard to sync the signal.
Posted on Jan 30, 2010
  • 2,517 Answers
Its ok just cool down. nothing going to happend.
Drivere sk-8125 pentru windows 7
If it's doing nothing then you have a bad USB port (move it to another USB port) or the USB keyboard is disabled in CMOS (usually hit F2 or Delete button during start up to get to). If the keyboard is working but isn't working correctly, there is something wrong with the keyboard. You probably just need a new keyboard.
Jan 30, 2011 | Dell SK-8125 Keyboard
Trying to install logitech wireless mouse on Acer laptop with Windows 7 but not seeing the device. Wireless button is on and active on the laptop
Wireless button on laptop has nothing to do with wireless mouse. Plug in your mouse receiver that come with the mouse in to a USB port on your Laptop. Turn on your Mouse and hold the reset or sync button on the bottom of your mouse for a few seconds, so that the receiver can synchronize with your mouse. Mouse should now work OK
Jan 04, 2011 | Logitech Cordless Mouse
Front usb ports are no longer working after I plugged in an external 2.5" SATA drive. The computer automatically powered off and I had to reboot. Now when I plug in even a flash drive nothing happens....
Hello
The connector of front panel may gone disconnected, you need to check the connector inside the compute and re-connect it properly.
Hope it helps, do rate the solution if so
Dec 26, 2010 | MSI 7529-050R Motherboard
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Nov 10, 2010 | Polaroid Cameras
Hello, I have a Belkin 2.0 USB 7-Port Hub, and having trouble with it. When i plug it into my computer, nothing happens, there is no power light and ultimately it seems as though the device is dead. ...
You first need a CAT 5 cable to go to where your internet connection is, such as a modem or another router to your hub. Then you plug another CAT 5 from the hub to your PC. You need to feed internet to the hub then your pc will recieve a connection from the hub. And of course the hub does need power. Hope that's what you were asking.
Mar 09, 2010 | Belkin (F5U237) 7-Port USB Hub
Device Driver Sofwtare will not install for HP
Hi, I have the exact same printer, with the same problem (Windows 7 Home Premium). Yes, the HP Windows 7 Software/Driver doesn't work for this printer.
But I was able to find a successful workaround. Follow these steps in Windows 7:
1) Click on the Windows Start Button and click on "Devices and Printers"
A window should pop up showing your devices and installed printers (if any).
2) At the top of this window, click on "Add a Printer"
A "Add Printer" dialog box should pop up with two options on what type of printer you want to install.
3) Choose the "Add a Local Printer" option. Ignore the small print under the option.
A window will now come up prompting you to Choose a Printer Port.
4) Choose "Use an Existing Port"
5) In the drop down box next to "Use an Existing Port", choose one of the USB ports. That entry should say something like:
"USB001 (Virtual Printer Port for USB)"
6) Click the "Next" Button
Now an "Install the Printer Driver" window should appear.
7) In the Manufacturer's Box, find and click on "Hewlett-Packard"
8) In the Printer's Box, find and click on "HP Deskjet 4200 Series"
9) Click Next
10) Follow the instructions on the screen to install. If Windows gives you the option to replace the current driver, then go with it.
11) Done! The printer should work. But everytime you plug it in, you may receive a notice from windows that the driver could not be installed. There are ways in Windows to hide that specific notice. But in any case, the printer should still print when you want it to.
Dec 02, 2009 | HP Deskjet D4260 Printer
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Low usb power out
the captr of the mouse is dirt, clean it.
Feb 06, 2009 | Acer Aspire 5520-5908 Notebook
IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Jan 30, 2008 | IBM ThinkPad T41 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
