Question about GE GSS20IEM Side by Side Refrigerator
Little door at top of refrigerator
The top 1/2 of my refrigerator is not cooling, would it have to do with the door at the top left inside corner? How do I fix that piece?
  • bdog0603 Feb 18, 2008
    Yes, the fan is running when the compressor is on and there is frost on the back.
    President:
  • 1,314 Answers
Yes it could you can open it manuely for now but may need to replace called a damper door assembly is there any frost on the back wall of the freezer section and do you hear the the freezer fan running when the compressor is
Posted on Feb 18, 2008
  • robert samples Feb 18, 2008
    ounds like you may be in the begging statges of a defrost promblems on the back of the freezer sidev after you pull the unit out should be a panel with three screws in it pull that panel and inspect the circuit board for any damage to the electronics then on the inside of the freezer pull the bottom of the freezer panel and see if the coils are all frozen up if they are thaw them out with a hair drier look at the heaters and i think you will see one of the heaters are burned out it will be black and let me know
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
How do I fix a refrigerator that won't cool?
if you are sure the evap fans are running (the ones inside) then only 2 things left.... 1- there is ice build up around the evaporators blocking air flow..... 2- the unit is out of freon.... I really suspect that there is ice around evap, samsung's are not known for having freon leaks.....I would unplug unit for 24-48 hours, then remove ff shelving, then take 2 screws out,(located on the bottom left and right of the evap cover and the one that is behind a plastic plug located in the center about 2/3 of the way to the top of the cover....once you remove the screws, grasp the cover on the bottom right corner and gently pull out to remove cover, being careful not to break the foam that channels air..... once removed check to see where the ice is left.... usually in the top right corner, if so replace the sensor located there... Ken Hawk
Feb 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
Fresh food side not cooling , freezer side works fine.Kenmore model #3639514711
check the electronically operated damper vent door located behind the plastic grille inside the refrige compartment in the upper left hand corner,its either a dead control,an evaporator control12 volt d.c. motor,or the motor/door shaft is broken and you need a repl
Jul 01, 2011 | Kenmore Side by Side Refrigerator
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Not cool enough
Make sure the air door in the refrigerator compartment is open at least a little and not blocked by anything. This is located just to the left of the bottom drawers. Also check the air inlet located at the top left rear of the refrigerator for flow. If none is present then you have a frost buildup caused by frequent opening and closing (common to these models) an ice cube dispenser door hanging partly open (Also common). Check this by looking from the inside of your freezer door down the ice chute. A flashlight helps a lot here. Also may be a defrost issue.
Mar 05, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE GSS20IEM Side by Side Refrigerator Logo
57 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
