Question about Cell Phones
Hi there wen making a call all i get is correction error
  • stenortheast Jan 30, 2010
    o2 network n97-1
  • 3,230 Answers
Well it seems that you activate some service by default on your phone, is your phone working fine else then correction error? what service you are using and what is the model number of your phone?
Please reply for more help or information........
Thanks
Posted on Jan 30, 2010
How to fix wen it displays a h8 code
H8 could be OutdoorCurrent transformer error
If you send make and model of air conditioner, that would help me help you?
Cheers
Jan 02, 2016 | Heating & Cooling
My android sumsung s4 can not select network settings. wen I select manualy it keeps on saying error while searching for network and wen I select auto it does not show selected network. wen I make a p
Hi
Samsung phones and probably most other phones store all networks detected throughout their lives unless you select them and tell them to "Forget" particular connections. This applies even when the network settings don't match the settings of the network you are trying to connect to.
I would suggest that you "Forget" the connection you are trying to connect to. After a while the phone will detect the network and if you tap this network it will ask you for a password. Enter this and it should connect it the network without trouble.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | Samsung Galaxy S 4 GT-i9500 Smartphone...
Error code 6be showing wen installing winxp
This error can occur due to any of the following:
The Catroot2 folder is not correctly deleted during the installation.
The random access memory (RAM) configuration is not compatible with Windows XP.
One or more of the RAM modules on your computer do not work correctly.
Nov 09, 2013 | Microsoft Windows XP Professional
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
Part 2 My subs are the ones that are making the noise it only does this wen I hook up the y adaptor to the sonic cabinet wen I plug it in to hi biamp my subs work fine but the cabinet still does nothing...
Make another video showing your connections on your amplifier I've hooked this set up before so I can understand partly what your saying, are your filters correct?
Mar 27, 2013 | Audio Players & Recorders
Wen driving like wen i *** to a stoplight or complete stop sumtimes it will shake and cut off but if i give it a lil gas it will nt cut off
The symptom is not having correct Fuel air mixture.
Make sure to do in order
1- Change the new air filter.
2- Have Fuel filter replaced.
3- Have Fuel pump delivered correct quantity per sec.
4- Have Fuel distributor calibrated
Good luck.
Aug 09, 2010 | Mercedes-Benz C-Class Cars & Trucks
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Nov 17, 2009 | Canon imageRUNNER 1023N Black and White...
I keep getting a memory card error on the vx2100
Hi there
Make sure the write protect is switched off on the memory card, take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 27, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Vioce error
i m using yahoo messenger 8 , i cant make conference call. there is error display (this computr does not support the requird audio compression....so pls solve the problm.
Nov 23, 2008 | Yahoo Messenger
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
