Question about E-Machines eMachines Desktop PC
Emachines t2865 My monitor wont turn on, i have it pluged into the tower, but i dont see a power cord for it? does it have a seperate power cord ?
    Genius:
  • 1,019 Answers
Most Monitors. Have A Seperate Power Cord.
They vary in shape and size. 2 pin 3pin et,c.
Have a good look at the back, and check. you should have a power connector socket inlet. And a cable out socket, to connect Monitor To Sound Card On The Back of the Desktop.
These can be located on the back underside of the monitor.
if in doubt search for your monitor make and model on the net, and try to get some instructions.
hope this helps Mike.
Posted on Feb 17, 2008
Emachine tower powers on disk drives open and close, there is no picture on the screen. how to fix?
Is the monitor plugged into the wall and power turned on?
Is the video output of the PC connected to the monitor?
Feb 09, 2015 | Quantum Technology eMachines eMachines...
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Monitor keeps saying no signal.Tried a new cord from monitor to tower but that did not help.The light is on the monitor to show that it is on.Help please.
connect another working Monitor to the tower, if this solve the problem send in the monitor to the monitor's authorised repair center. If the problem is not solved, replace the Vedio card on the tower
Dec 28, 2009 | E-Machines eMachines Monitor E15T4
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
E machine t2482
Try changeing the RAM and if that dosent work try the processor
Jun 02, 2009 | E-Machines eMachines Desktop PC
Tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Mar 28, 2009 | E-Machines eMachines Desktop PC
Emachine tower unresponsive
Unplug the Monitor, and attempt to reconnect a seperate monitor to test. If that monitor works properly, then the problem is your regular monitor. If you do not have another monitor, Try unplugging the power from the wall jack to the tower. Then plug into another port, the reason the computer doesn't turn on is because the power outlet may be running but at a lower voltage then what is required for the computer to run at its full potential. If theese both fail, Try opening your computer and check if anything is blown out.
Feb 07, 2009 | E-Machines eMachines Desktop PC
The computer does nothing its stuck in test mode
I think your PC got static build up just leave the PC for some hours and try pluging back the power cord.
Nov 19, 2008 | E-Machines eMachines Desktop PC
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
E-Machines eMachines Desktop PC Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
