Question about Asrock P4I45GV R5 Motherboard
Hi dis is Pradeep, there is no display on my monitor but am getting audio,pOWER LED is glowing.2 dayz back i have added pci to vga graphics card for bad problem in display.But now new problem.I can hear the windows starting sound also.Plz suuggest me to overcome all these
  • 77 Answers
I think vga card not support in ur pc.This cards is support is ur pc Club 3D R9800/128MB Catalyst 3.8 ATI Radeon 7500 Colorful R7500/64MB Catalyst 3.8 ATI Radeon 9000 Colorful R9000/64MB Catalyst 3.8 ATI Radeon 9200 ELSA FALCOX 920FX 6.14.10.6458 ATI Radeon 8500 LE Gigabyte GV-AP64D Catalyst 3.8 ATI Radeon 8500 Gigabyte GV-AP64D-H Catalyst 3.8 ATI Radeon 7500 LE Gigabyte GV-AR64S-H Catalyst 3.8 ATI Radeon 9000 Pro Gigabyte GV-R9000 PRO Catalyst 3.9 ATI Radeon 9200 Gigabyte GV-R9200 VIVO Catalyst 3.10 ATI Radeon 9200 Gigabyte GV-R9200 VIVO 128MB Catalyst 3.10 ATI Radeon 9500 Gigabyte Radeon 9500
Posted on Jan 30, 2010
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
Adding discrete graphics card to p6stp-fl
!O_O!
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds. Let go. (HAS to be 10. Count)
Do this same procedure TWO more times.
(IF the Power On LED flashes for a second, keep repeating until it doesn't)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
3) FOLLOWING Anti-Static Precautions remove the graphics card.
Plug the monitor back into the Integrated (OnBoard) graphics, of the motherboard. (VGA connector)
4) Plug the computer back into power. WAIT 1 minute, turn the computer on.
5) When Windows has loaded wait a couple of minutes, then take that graphics card's Installation (CD) Disk, and put it in the optical drive.
If the disk doesn't start loading after 10 seconds, go to My Computer, and double-click on the drive letter, next to the optical drive, the Installation Disk is in.
When asked choose all software. Nvidia Control Panel, and drivers.
Your computer will keep on using the Integrated (OnBoard) drivers, for graphics. It will Not use the drivers, and software you are installing now, until the graphics card is physically installed.
Install all software. If you are asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off normally.
(Start > Turn Off Computer > Turn Off)
6) Unplug from power, follow Anti-Static Precautions.
Unplug the monitor from the motherboard. Physically install the graphics card.
Plug the monitor into the graphics card. Close the computer case.
7) Plug into power. WAIT 1 minute, turn the computer on.
You may have to go into Nvidia Control Panel, and set the correct parameters for your monitor. (Screen Resolution / Color quality )
Clear CMOS Error Codes, and reset BIOS Setup back to factory settings doesn't work?
You get to go back into BIOS Setup, and set the submenu you changed, (Or submenu's), back to the factory standard setting.
(F6?)
You are trying to use the OnBoard graphics drivers for the -> graphics card. This = NO.
You need THE drivers for the graphics card installed F-I-R-S-T.
(OnBoard. ON the motherBOARD.
Used to be used for Integrated Graphics.
Makes it easier to understand if you use OnBoard Graphics )
Why?
When a device, (In this case a graphics adapter card), is installed, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
You need THE drivers already installed. Windows looks to see what device is installed, then finds THE drivers needed.
Regards,
joecoolvette
Sep 13, 2012 | EliteGroup P6STP-FL Motherboard
Analog output cannot display video mode
Hi, there!
Please check the connection of DVI or VGA cable which connect between your computer box and monitor. Check at the back of your computer box, how many VGA ports(the blue port)? If your computer box have 2 VGA ports( one in-built on-board and one from added graphic card), always connect to the one from added graphic card, not the one on-board. Hope this help. Thanks for readin.
Jul 11, 2011 | Dell Monitors:Dell 1801FP Driver
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
May 14, 2011 | Computers & Internet
Need to connect 3 monitors. Want to use either a Nvidia 290 or ATI Radeon 9250 plus the VGA port. Installing the dual-video card disables the VGA port, cannot get it back. Help!!!
Use your AGP dual-video card for two and using a PCI VGA card for the third. It is best if the same manufacturer video driver is used for both cards, as two different ones could be problematic.
Jun 25, 2010 | HP Compaq Business dc7600 PC Desktop
Will a dell dimension 2100 support dual monitors
Yes it will but that will also depend on your graphics card to a degree.
To do it properly you need to install a new graphics card and disable the on-board graphics card from the bios.
Your new card should support std VGA as well as DVI
DVI is also capable of being hooked up to many large screen tvs
Aug 20, 2009 | Dell Computers & Internet
A display problem of monitor comes with geforce 9400 gt pci ex. card. how can i solv it? when i insert cart the display of monitor out. how can i solv it?
According to the specs of the MSI 9400gt 512mb HDMI graphics cards, its system requirements are:
1. PCI Express or PCI Express 2.0 - compliant motherboard with one x16 graphics slot.
2. Power supply of 300 (and up) watt is highly recommended for system stability.
Make sure that your power supply meets the or exceeds the system requirements for this graphics card.
Jun 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
Asrock P4I45GV R5 Motherboard Logo
109 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
