Question about Frigidaire PLD4375RFC Dishwasher
"Runaway Dishwasher" Brand new model#FDB520RHS2 Frigedaire was installed today. It was on normal wash and did 8 washes and rinses. It wouldn't switch to the heat cycle. I hit the cancel button after 2 and half hours of washing and rinsing. The water emptied. I then opened the door and let it air dry...I am upset that it did this crazy thing. Do I have a lemon? What would you suggest???
    Brigadier General:
  • 4,088 Answers
Ask for warranty repair or replacement.
Posted on Jan 30, 2010
How much water does a dishwasher use per cycle
auto clean 4 to 10 gal
heavy wash 10 gal
normal wash 4 to 8 gal
light wash 4 to 6 gal
rinse only 2 gal
Jun 14, 2014 | Maytag MDB7100AWB Dishwasher
Frigidaire dishwasher model FDB520RHS2 will not advance pst wash- just keeps washing draining and refilling the wash. does not advance. Left it run for 3 hours, still wash only
We had a problem with our dishwasher, it just went crazy one day and lights would light up but ours did not wash or anything...anyways upon further investigation found out by taking 6 large round head screws off,, the handle and outer cover came off, then there was a cover that was covering a circuit board and this was the brains of the washing machine, ordered the part from sears 160.00 and washer is all set. good luck. oh ya, upon further exam. when I took the board off could see discoloration on part of the circuit board. this means burned out resistor or fuse.
Mar 22, 2014 | Frigidaire Dishwashers
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Brand new dishwasher does nothing but wash & rinse
Time for warranty replacement or repairs! Good luck!
May 14, 2010 | Frigidaire PLD4375RFC Dishwasher
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button as well as the heat dry button and the high temp button do not work. only button that will light up when pressed is the delay button. How can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
Oct 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire PLD4375RFC Dishwasher Logo
267 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
