Question about Bushnell Elite 6500 4.5-30x50mm Riflescopes 654305M 654305MD Waterproof Rif
Turrets on my elite 6500 have been overtightened in the clockwise direction to the extent of the clicker settings and when I try to click then back the other way the whole turret unscrews, how can I fix this?.
  • 115 Answers
For this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Posted on Mar 24, 2010
How to set my scope with a crosman fury blackout .177
Take both turret covers off and shoot 5 rnd group if group down and left rotate top turret up side turret counter clockwise a few clicks and repeat until you get on target
Also look on YouTube for videos on zeroing airweapons
Aug 09, 2014 | Crosman Optics
The turret is out of center on sl25mc lathe
The front turret bolts will need to be removed. Remove bolts in face of turret. There should be some adjustable bolts that will allow you to move the turret back in the correct position. Load a precision ground block into OD tool holding slot, usually tool 1 position. Hang it out around 4 inches. Indicate this block within .0005 or as close as you can get it while tightening the set bolts. It usually takes a couple of tries. Also the spindle might be knocked out as well. You can check spindle by cutting between centers. If it cuts tapper then it is also out of alignment. Hope this helps...
Dec 20, 2013 | Samsung Tools & Hardware - Others
How do I reset MurGee Auto Clicker?
I'd recommend that you try asoftech auto clicker which is very easy to use, and more powerful.
Jun 14, 2012 | MurGee Auto Clicker MurGee
How do i zero my tasco silver antler rifle scope
Start out at 25 yards. the scope is I believe used 1/4 inch clicks. This is for 100 yards so 16 clicks will equal 1 inch at 25 yards. Fire three shoots from a solid rest. Measure the distance left or right and up or down from the desired point of impact. and move the setting in the desired direction. ie uo is moving the point of impact up from where it is. and left or right is the same. Next fire at the desired distance and move point of impact to where you want it at that distance. If the scope is wandering all over the target make sure the scope is not moving in the mounts. If it persist in changing point of impact send it back to tasco for a replacement as it has a loose recticle. Better yet I can recomend Leupold or Burris as a better alternative if they are in your budget. Not quite a S&B or Ziess but **** close for a lot less $$$$$
May 24, 2012 | Optics
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
How do you reset W&E back to factory "zero",
Step 1 - Turn one adjustment turret all the way to one side,
Step 2 - Turn it back the other way, counting each click,
Step 3 - Turn it back in the original direction 1/2 the total number of clicks you counted in step 2.
Step 4 - Repeat with the other turret.
Nov 02, 2010 | Bushnell Banner Dusk & Dawn 6-18x50...
My suspension is too hard at the rear. Why? all suspension settings are set at their lowest and still it's like riding around with a solid rear end.
Its an older bike. Check your linkage, make sure nothings been overtightened and all the bearings are greased. Run all your clickers in and back them both back out 7 clicks or so. There are both compression and dampening adjusters. One on the cartridge and one down near the linkage.
Jul 10, 2010 | 1997 Honda CBR 600 F(3)V
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Touchpad right and left clickers womt work
this is due to the driver missing or uninstalation of the touchpad you must try to reinstall the driver again.
for any harware problem you can check the status in
DEVICE MANAGER present in CONTROL PANNEL(WINDOWS VISTA)
for
WINDOWS XP you can search this application in windows search.
Apr 20, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Bushnell Elite 6500 4.5-30x50mm Riflescopes 654305M 654305MD Waterproof Rif Logo
99 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
