Question about Kenmore 24032\24036 Top Load Washer
My washer barley agitates..checked the motor coupling... it looks ok
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Sounds like you may have a bad transmission. sorry. unless it's a multi piece agitator and it's top portion thats not really worling. if thats the case there are4 dogs that can be replaced.
Posted on Jan 30, 2010
All the program working normal except agitator cycle
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 06, 2015 | Hoover Washing Machines
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
Apr 03, 2015 | Whirlpool Washing Machines
Samsung washing machine model no WA80T4G everything is alright water also taking inside but wash & other options not working
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Samsung Washing Machines
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
Jan 06, 2015 | Maytag Washing Machines
Washer won't agitate or spin
Oct 12, 2014 | Whirlpool Washing Machines
Water loads up but does not wash nor spin but does drain
Motor Control Board he motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 09, 2014 | Maytag Neptune Washing Machines
I have replaced the agitator dogs on my washing machine. Machine will fill and drain but will not spin, the macine even after replacing the dogs barley agitates. What could the problem be? Kenmore 70...
the motor coupling is the most likely problem
this video will show you how to replace the couplinghttp://www.youtube.com/embed/9K1KHEogf3c" frameborder="0" allowfullscreen>
Jul 19, 2011 | Kenmore Washing Machines
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
I have a model 110.81375130 Kenmore washer that is making a grinding noise during wash cycle. I already replaced the agitator shoes (similar to agitator dogs on other models). The bottom agitator is only...
A grinding noise from a washer more often than not means that your motor coupling is worn or broken. The coupling is a small plastic and rubber piece between the motor and the transmission. Not too difficult to replace yourself and very inexpensive. If it is the coupling you may see bits of rubber beneath the machine. If you look up underneath the machine it will be obvious of the coupling is your issue. If not I would recommend calling a licensed repairman to check it out.
Dec 12, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will barley agitate or spin and make a
Try high speed only (cycles like cottons, heavy duty, etc. This happens when the low speed on the motor is not working. If high speed is working for you, the olny way to make the lower speeds work is to replace the motor.
Your part number is WH20X10019 and it's expensive...
Oct 20, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
