Question about iLO 3200 32 in. LCD Television
I have a viore tv and my remote does not work anymore, i would like to try and repair or reset the remote to turn off the tv, and turn the volume up and down.
SOURCE: Telvision Problem
Do the controls on the tv itself work or just the remote? If it's the remote mabey it's defective. I would look on the Ilo site and see if they recommend a universal remote for their models ( or just getting yours replaced ). If the problem is within the tv, I'd look into the warranty. Sorry if this wasn't any help.
Posted on May 23, 2007
  • 6 Answers
SOURCE: Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Posted on Apr 11, 2009
  • 6 Answers
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Posted on Apr 20, 2009
  • 37 Answers
SOURCE: dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Posted on Jul 06, 2010
SOURCE: Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
Posted on Feb 05, 2011
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
May 17, 2010 | Toymax Viore 42 in. Plasma TV
Dish network code for a viore, volume/power not working
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
My KDS-R60XBR1 turn up volume to maximum loud and stays loud
Question:
Take the batteries out of both the remotes and then try to turn the TV on with it's On/off switch built into the TV.
If it turns on and the volume stays the same, then it must be an issue with one of the remotes.
If the tv turns on and the volume ramps up to max. Please check if volume knobs/buttons on the tv itself to see if they are sticking.
If they aren't, there is something wrong with one of the boards in the tv of course. This sure should be something a Sony Service Shop can fix. I don't think it will be expensive. Maybe a $100 to $200 repair if they do the work.
Blessings,
A/V Media Guy
Nov 20, 2009 | Cameras
Avex universal remote programming for Viore TV
Have you tried the search method?Turn the tv on manually. Hold the TV button and the SELECT button down together on the Avex remote until the light comes on. Then use the up (or down) arrow button to scan the codes. Use the up (or down) button slowly but quicker than 30 seconds. If it comes across the right code the tv will turn off. If the set goes off press the power button on the remote to turn the tv back on and test the volume and channel buttons for operation. If some of the buttons don't work continue pressing the up (or down) button until the tv cutts off again. When (and hopefully if) you find the right code press the TV button on the remote again and the light will blink 3 times to indicate it is programmed. I do hope this helps and thanks for using Fixya.
Nov 05, 2009 | Televison & Video
Viore LC32VH55 HDTV IR code. Is it updated in the URC-4021 controller ? TV uses NEC1- Protocol 96-157. I think the code is an AKAI of 1207. Cn U verify and solution
After A LOT of blog reading and a few tech support calls, I think the only codes are 11207 and 11684 but neither work for my new Viore LC32VH55. I wouldn't have bought it had I known it wasn't compatable with Directv! I can't believe that there's no solution for this... I can't turn the volume up or down without using the tv remote and I'm so frustrated!!! Anyone know if a universal remote will work for both the Directv receiver and this stupid Viore TV?
Don't buy a VIORE! It's an okay tv but not worth the hassle!
Oct 17, 2009 | One For All URC-4021 Remote Control
Code for viore tv through directv remote
buy a vcr and antena in,antena out toTV you can change channels all day long.but volume has to be worked by hand.
Jun 28, 2009 | Televison & Video
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
Mar 09, 2009 | Toymax Viore 42 in. Plasma TV
iLO 3200 32 in. LCD Television Logo
308 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
