Question about Fisher and Paykel DEGX1 Electric Dryer
Beeping dryer Hi there We have a Fisher and Paykel dryer and it works for about 2 seconds and then stops and beeps. Any suggestions on how to fix it? Thanks
    Problem Solver:
  • 4 Answers
Simple solution for mine was to put a rubber door wedge under the door sitting along the control panel ledge. This allowed the door to activate the sensor. Easy solution. Hope it works for you.
Posted on Aug 06, 2010
  • Fisher and P... Master
  • 12,061 Answers
In all likely-hood a sensor or the like has failed, or even perhaps the micro... Check ALL the sensors, Try a reset if able to do so. Give the Bowl a good shove side to side, & around, to perhaps help any sensor problems. generally though they are pigs of things. If you must go to a repair place ensure you get a firm "Quote" before proceeding.
Posted on Jan 30, 2010
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
How do I clear the error on a Fisher and Paykel DW60CSX1 error message E6
to fix essentially you need to reboot... unplug at wall - wait about 30 seconds - 1 min then replug. should reboot and be back to normal.
if you can, pull drawer out at end of cycle so condensation does not cause this problem going forward... ours does this when it's higher humidity
May 18, 2014 | Fisher and Paykel Dishwashers
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Apr 29, 2009 | Fisher and Paykel Dryers
Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
Sep 21, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel DEGX1 Electric Dryer Logo
313 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
