Question about Kenmore Elite HE4 Electric Dryer
My Dryer just stopped working in the missle of a
My dryer just stopped working in the middle of a load. I looked inside and the light turns on. I tried turning the c breaker off, unplugging, replugging with C breaker on, still nothing. Help! I'm broke and have three boys under 8 who need their baseball uniforms! When I press the start button I can hear a little click, but no action. drum won't roll.
  • 1,531 Answers
With your door open have some one try and turn the dryer on while you hold the button in and turn the drum by hand to get it started.
if it starts the your motor may just have lint build up around it causing the contacts to be dirty.
there is a couple of other things that might have gone wrong the main control board has gone bad or the door switch, motor has gone out
Posted on Jan 30, 2010
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
My dryer just stopped running in the middle of a load and will not turn back on. Is there a reset button?
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 06, 2011 | Dryers
I have a Kenmore 400 series top loading electric dryer that just stopped working right in the middle of a load of clothes. It was working just fine and then it just stopped. Now it will not turn on at...
Hi there....this sounds to be like you blew the breaker. Go to your breaker panel in your house and search out the fuse for the dryer. This will be a double 110 volt breaker. You need to reset both sides to be sure. It is easily locatable as they almost always have the items listed on the inside of the door of the panel. If this works for you great. Please try to remember to click on the yes box on your way out ...thank you and good luck.
Oct 10, 2010 | Kenmore 73952 Gas Dryer
Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 01, 2010 | LG DLE2532W Electric Dryer
Hello, my kenmore dryer just stop working, light inside is still on but will not turn or come on Mod# 110.c66492500
Is the door completely shut? Did it stop working right in the middle of a cycle? Are you drying shoes in this load? I'd turn it off, and try it again. If this doesn't work, try it on another drying cycle. If this doesn't work, feel free to contact me again. I hope this works for you. Good Luck! Jim
Mar 30, 2010 | Kenmore Dryers
Wirlpool Duet Dryer front Load
I have never seen one up close nor worked on one, but if it was me I would look for a cause to the broblem. I would eliminate the simple stuff like power to the equipment and loose connections. I would then look for the fuse on the dryer and find the blockage or cause of the problem.
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Aquarius WD645 - dryer has stopped heating up
there is a safety device to prevent overheat. this can be a resetteble stat ie with a little button in the middle - press this button and there may be a little click as it resets. dryer will then work.
other type of safety device is a thermal fuse. this will be mounted on top of the dryer duct inside a sleeve. test for continuity and if open circuit, replace it
Apr 21, 2008 | Hotpoint WMA46 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
