Water will not drain
Thank you very much for your help, I recently had the door gasket replaced by a service company, I complained after the repair was complete that the door was not in alignment and it had to be physically lifted up to close the door. . Is it possible that this miss alignment caused the door control to fail. I made an error in my model number it is WFXD5201UC , Thank you for all your help
  • ermedic Feb 26, 2008
    Thank you for all your help !
  • 770 Answers
Yes this will casue the pin to break off you most likly need to replace the latch assby
Posted on Feb 25, 2008
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
Bosch shu8805 (2002 model)
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
  • Lower rack
  • Spray arm
  • Spray arm support
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
MAH4000AWW- Boot Seal
Friend,
ngfam1 At your service!
It is is normal for the Neptune to have water left in the inner tub after the wash finishes!
I used to have a Neptune and I sold them too!!
I had them change that drain under warranty when it was new and it never stopped the smell or the mold!
After the third repair I threw it in the trash and bought a Speed Queen Commercial grade washer and thats the last one I will ever by!
8 loads a week for 25 years!!!!!!!
The moldy oder problem is in every Maytag Neptune made!
The Neptune comes new with water in it from the test run!
All the water never gets totally discharged. This is one reason why everyone complains about the moldy, musky or even stinky smell of the Neptune! Every day I have people here asking what too do about the moldy wet smell!
THIS IS SERIOUS!!!!!
I do tell them to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make suer to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
That's Maytag!!!!!!!!
GOOD THING WHIRLPOOL JUST BOUGHT THEM OUT LAST YEAR!
Perhaps they will make some good changes!!
Hope this helps and makes you feel a little better as to some water sounds! HOW OLD IS THE WASHER??????
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Jun 16, 2008 | Danby 22 in. DDW396 Free-standing...
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Door Switch Er:04
Yes there is a tab that goes into the lock mech. and the misalignment will cause damage to the latch assby
Feb 21, 2008 | Siemens WFXD5200UC Front Load Washer
Washing Machines Logo
236 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
