Question about Cameras
Nikon Coolpix S210 Digital Camera .Lens Error Lens is stuck out. No i did not drop it.went 2 use turned it on i got a lens error.HELP
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 30, 2010
Lens error
lens error: will arise when the gear mechanism gets stuck, either by itself or by a finger touching the barrel of the lens when trying to operate.
Aug 02, 2010 | Nikon Coolpix S210 Digital Camera
Hi everytime i try to turn on my nikon s210 the lens will not extend and it dislplays a lens error
This is probably THE most common failure among digital cameras, and it can be caused by dirt, dust, grit, or dropping, among other things.
There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 13, 2010 | Nikon Coolpix S210 Digital Camera
Hi im trying to find out how to fix a nikon s210 lens
Try to reset the camera or take it into Nikon it might be damaged
Dec 13, 2009 | Nikon Coolpix S210 Digital Camera
Lens error
Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts.
Oct 24, 2009 | Nikon Coolpix S210 Digital Camera
My 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Jul 31, 2009 | Nikon Coolpix S210 Digital Camera
My nikon coolpix s210 has a lens error. I turn it on and the lens comes out. It make a err sound and seems like it cant focus. it goes back in and says lens error until i turn it off. I need it. I cant...
if its brand new, then you can replace the lens array for free of service charges in the case you have all the documents. it generally happens if you have dropped the camera.
Jul 09, 2009 | Nikon Coolpix S210 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 03, 2009 | Nikon Coolpix S210 Digital Camera
Coolpix S210 Lens Error
I think I answered this one earlier. Is the lens stuck? If so, help it out with a little screw driver. Worked for me!
Dec 06, 2008 | Nikon Coolpix S4 Digital Camera
Cameras Logo
710 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
