Question about D-Link Xtreme N DIR-655 Wireless Router
I do not see my network to connect my wireless computer to. What happened to it?
  • D-Link Master
  • 32,281 Answers
Check Device Manager to see if the wireless card is working and enabled. If not install the latest wireless card driver and then configure it with the router's wireless settings ie. SSID, WPA encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Jan 30, 2010
Setings to connect wifi
What is happening when you try to connect? Do you see your wireless router or ssid when your view available wireless networks? Have you put the password in correctly if it asks you for it? Does your computer say you are connected to a network? Have you turned the wireless switch on the laptop on?
Give us more details on what is happening.
May 21, 2012 | Computers & Internet
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
EPC smart book cannot conect to internet
make sure that your wireless network card is turned on. reinstall your wireless network card driver. if nothing happened, consult your manufacturer. possible defective wireless network card. you can also test your router by using other computer if that computer can connect to your wireless router. if yes, then the problem is your computer. if not, then problem is your router. hope this helps.
Apr 01, 2010 | Computers & Internet
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
My wireless network connection status in connected Speed is11.0 and my signal strength is good, but I cannot connect to the internet connection godd but internet explorer cannot display the webpage
You are getting local access only.
Right click on the icon in the system tray and click repair....
If it still happens you need to connect to a different network..this usually happens if you are connecting to an unsecured network (I assume yours).
Alternative: Unplug the network adapter. Turn off the computer. Wait approx 2 minutes.
Power on computer with net adapter connected....
Dec 18, 2009 | Sony Computers & Internet
Whilst online my connection went off using my belkin 54g, and wont let me connect again as it says, 'The settings saved on this computer for the network do not match the requirements of the network'...Why...
That message means that your wireless security key has been changed to a different password. All you need to do is go to Network and Sharing Center > Manage Wireless Network, then delete all the listed wireless profiles there. Now click on Add > Add a Network that is in range of the computer > Choose your network and connect. Make sure to type in a correct network key. That should do it.
Apr 18, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Cannot connect to router wirelessly.
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
May 09, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Computer disconnects from Internet when my neighbor is using his computer
the Lock means that he has a secure network or he has the WAP enabled.. Can the two networks interfere? Yes. The two networks will "fight" over which one will your computer use to connect.. and sometimes you will connect to his network and therefore get no internet or limited connectivity.. You can make sure that your computer only connects to your network by permanently removing his SSID from your settings.
Mar 25, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
I can't connect to the router
Well since ur second computer goes online with wireless connection, so it seems the problem with your first computer.The only thing that you have to do is to update your wireless card drivers. Detailed answer: 1. Restart your computer in safe mode with networking mode. 2. Uninstall the wireless card. 3. Restart the computer and install the card again. This will definitely resolve your problem. Goodluck. ( Got the solution from ***)
Aug 27, 2006 | ASUS WIRELESS ROUTER |WL-520G - RT...
D-Link Xtreme N  DIR-655 Wireless Router Logo
106 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
