Question about Radio Shack Cinego D-1000 Multimedia Projector
Doesn't turn on
1st my projector would turn on but the bulb didn't turn on. I ordered and replaced the bulb. I got one of those air blowers that you use to clean your computer and tried to clean it.But on the projector would turn on. I tested the power cord and it's ok. Is there a reset button or did I burn something out when I cleaned it? Pls. what should I do. where can I send it to get repaired. need to have it repaired. pls help. Thank you
  • 53 Answers
Mmmmmmm
Posted on Apr 26, 2008
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
2001 HYUNDIA SANTE FE BLOWER QUIT WORKING CHECKED FUSES STILL GOOD
If this is the Manual A/C type, there are two common occurances affecting blower operation.
1st, there is intermittent contact in the blower motor brushes. You can check this by locating the blower motor housing under the dash on the Right Hand side (Passenger Side). With the Ignition Key in the "ON" position, blower switch on "HIGH" firmly slap the housing with your hand. If the motor starts working, there's your problem. If it doesn't, rig up a 12 volt test light bulb and back-probe the connector to the blower motor - Does the light bulb turn ON? If so, then the problem is with the blower motor itself. If it DOESN'T turn on, then the problem is elsewhere (blower relay, blower control switch, or wiring to the motor or from the motor to ground.
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, campaigns, illustrations and procedures, etc.
Sep 05, 2011 | 2001 Hyundai Santa Fe
How do i clean the filter on my vp6325 projector?
If you have a jet air - compressor or blower- use it to clear the filter of the trapped dust within the filter. Once the filter is clean the flow of air to the lamp unit will be improved and so give you longer life on the lamp. A tiny bristle type brush can be used-- the brush of your electric shaver.
Jan 18, 2011 | HP vp6325 DLP Projector
Why dull lightoutput coming from the projector sony vpl ex 5
Its because of dust.Out bulb throw air to bulb and at projector through air blower or vacuum cleaner.You will get better result
Aug 04, 2010 | Sony VPL-EX5 Projector
I replaces my bulb in the sony vpl-hs10 and it still will not turn on after I reset it what do I do now? the lamp light is still lite it turns on but the lamp does not project anything
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Nov 19, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Sony vpl-hs20 cineza projector- reset lamp counter
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Cleaning my air filters
air flter is on the left of the projector; just click the plastic cover off and then vacuum the filter: if this doesn
Dec 10, 2008 | Hitachi CP-X275 Multimedia Projector
171 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
