Question about Whirlpool MH7130XE Microwave Oven
Whirlpool microwave fan spontaneously came on
We had a problem today, with our Whirlpool microwave oven. While not using the microwave at all, the fan spontaneously came on and would not turn off. The underside of the microwave got extremely hot within less than a minute. We unplugged it but are scared to plug it back in. It seems like it was about to catch on fire. Why would it spontaneously come on like that and get so hot?
  • 1,531 Answers
Some of these unit detect heat from the stove while cooking.there are designed to turn the exhaust fan on until the temprature gets cooler to prevent any interior damage.
there also could be a problem with your microwave circuit board.
check with whirlpool and see if there is any recalled notices for you microwave
Posted on Jan 30, 2010
  • seth adams Jan 30, 2010
    also check the inside of your door if you serial number starts with the letters xc then there is a recall on this unit if it has a green square in the door or it does not start with xc then you should not be under a recall status.and should have someone check it out
I have a whirlpool combination microwave with oven. How do I change the bulb in the microwave?
Whirlpool Microwave Bulb Replacment - YouTube
? 4:35
https://www.youtube.com/watch?v=RQM302PShKw
Oct 29, 2011 - Uploaded by Dan Jiles
I show how to access the bulb on a Whirlpool Microwave that shines on your cook top, as well as how to access and replacethe bulb that is for the microwave ... ... How to disassemblemicrowave oven. Find info: fuse, bulb, fan ..
Nov 07, 2015 | Whirlpool Microwave Ovens
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
Oct 16, 2014 | Microwave Ovens
WMH32517AW Whirlpool Over-The-Range Microwave-No Fan
Go inside and check all of the connections related to the fan. Check the fuses, and the fan itself.
Nov 06, 2013 | Whirlpool WMH32517AW 1.7 cu. ft....
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
"SE" error means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced.
It's actually a pretty simple DIY repair.
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
Some connectors on the relays have a lock:
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
Plastic fan cover
the fan inside of the microwave is to draw out the hot air during cooking. you can use the microwave as is. but woould be nice to the cover, just incase some food gets pull up into the fan.
Dec 12, 2008 | Whirlpool MH7140XF Microwave Oven
Spontaneous fan on/off
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Dec 11, 2008 | KitchenAid Microwave Ovens
My built-in KitchenAid microwave/convection oven/oven fan comes on and goes off spontaneously. I have to turn it off at the breaker. Otherwisel, both micro/convection and the lower oven are functioning...
I have the same problem
any hints to solve it.
It's a 1988 vintage oven/microwave so I can't complain but it 's a pain if
I have to replace the unit
Dec 11, 2008 | Microwave Ovens
Whirlpool GH5184XPQ 1100 Watts Microwave Oven Fan Won't stop running
If it's new, it should still be under warranty, so I would contact Whirlpool at http://whirlpool.com/custserv/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
1,001 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
