Question about QSC MX1500A 2-Channel Amplifier
How do i bridge my mx 1500a because I dont have a manual for it? can u tell me which terminal i can used thanks in advance.
    Champion:
  • 211 Answers
There's a switch on the rear, put this in bridge mode.
Connect you speaker (not under 4 Ohm) on the two red outputs.
Here's your manual.
http://media.qscaudio.com/pdfs/mxusr.pdf
Good luck,
Gerard
Posted on Jan 30, 2010
  • sheldon harris Oct 28, 2012
    turn channel 2 volume down, connect 4 ohm minimum load to the two red binding posts of ch1 and ch2. use channel 1 input to drive the amplifier. dont gorget mx1500a is pin 3 positiveso speakers would be reverse polarity if you are using a diffrent amplifier to drive the other speakers.
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
I have one this modem i dont Know this is for what pleas send me details
I please click here to see the user manual to know how it works and how to configure your router as well what is the use of this router.
Thank in advance!
With Regards,
Prema.
Jan 19, 2011 | Lucent CellPipe 20A-USB (300402633)...
Can i bridge a sony xm-1600gsd amp???
try connecting power to one terminal and the negative to the other terminal this will bridge the amp
Jan 29, 2010 | Sony Car Audio & Video
Question similar to ...connect to home theater... What kind of fan noise do these amps (QSC MX 1500a) have if using in a home theater or stereo system in the typical room?
Hi
I work with these amplifiers every day and i can tell you that they not made with quietness in mind.
They are mainly used in a club/disco environment and often mounted in a equipment rack hidden in a closet. Excellent/tough amplifiers if you want power and clean sound ,but
You may find their noise level uncomfortable in a living room.
Hope this help Merry Christmas
Dec 21, 2009 | QSC MX1500A 2-Channel Amplifier
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
Need more rockford fosgate help
USUALLY, it's the 2 outside ones. I believe it's the L+ and the R-.
Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
On lucent amps you sometimes have to bridge two terminals together to make it work. i need to know what two need to be bridged.
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
Jun 02, 2008 | Audio Players & Recorders
Can't program mx-700 remote
Hello there,
I just had the same issue and solved it- its pretty easy as it turns out. check out
http://www.universalremote.com/resources/pdfs/MX600manual.pdf
This is the previous model owners manual but it works. You'll want to program using the "learn" mode where you point the remotes at each other.
Feb 28, 2008 | Universal Remote Control MX-700 LCD Remote...
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Yamaha P4500 Power Amplifier 2-Channel Bridge mode
im from Yamaha service before and i know this model can handle as low as 2ohms per channel. I have to check on my manuals though if bridged. i dont see any reason why it cant. and it has a bridge option input stage... let me get back to you again in the days to come.
or email me redrivera0314@tyahoo.com
i have a service manual to check on this. got to dig on my closets..
Mar 14, 2007 | Yamaha P4500 Power Amplifier 2-Channel
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
268 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
