Question about Car Audio & Video
Hi I have a 1998 Ford Windstar GL 3.8 V6, I need a help in getting info on a part it is, Heated 02 Sensor Bank 2 Sensor 2, Can You tell Me were in Boise Idaho can I find it and also can You give Me the Ford Part number that will make it easy for Me, I am disable and can't drive all over to try to find what I need thanks for Your time and info. >> Harold
  • Harold Diehl Jan 30, 2010
    Very much now I know what to ask for, There is a Autozone in Boise Idaho about 2 miles from Me thanks again. >> Harold
  • 2,926 Answers
The O2 sensor for 1 and 2 are the same p/n and are identical in sahpe and size including the connection.
Here are the AutoZone locations;
308 North 10th Ave.
Caldwell ID 83605
(208) 453-9454
145 South Washington
Emmett ID 83617
(208) 365-5272
I did not have your zip code, but Autozone will direst you for the location closest to your residenceThanks, Dennis
Please accept.
Posted on Jan 30, 2010
  • GetMeOttaHere Jan 30, 2010
    Your welcome. Thanks again.
Im getting code P2253 on my 04 Saturn vue with 3.5l V6. Anyway to tell which O2 sensor it is? Thxs Bill
P0804 is the highest OBD-II trouble code.
Here's your Oxygen sensor codes.
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Note: "Bank 1" is the side of the engine with cylinder 1. "Bank 2" is the other side.
Jul 03, 2011 | 2004 Saturn VUE
I have a 1998 ford windstar and i need upstream & downstream 02 sensor but i dont know if i need 1 or 2 upstream sensors.
assueming it has the v-6 in it look at the exhaust pipe comming off the side of the engine there will be two up stream 02 sensors which are heated and one downstream past catalitic conveter. If may have the second style with the Y cross over with 1 upstream before the cat and one after. The difference between the 0-2 sensors is the upstrean are heated so it goes into closed loop faster. I find that on most of these the up stream 02 sensor heaters have failed. You can go to a Autozone and they can pull the codes for you and tell you which side it is that needs to be replaced. However 02 sensors get old after time and they start shifting slowly, if it shifts slowly then it's called a lazy 02 sensor. And will send a code to the computer, if you get the trouble code of the 02 sensor heater is bad you will have to change it, I recommend Replacing both. The reason is if one is going bad the other will soon follow. You can buy a socket wrench For the 02 sensors for 12 dollars makes it real easy to replace the 02 sensors when they are COLD. Hope this helps and thanks for using fix-ya.
Sep 14, 2010 | 1998 Ford Windstar
2000 windstar service light on
Your van has four o2 sensor's, the code should tell you which one is bad for exsample code should be like,
o2 sensor bank 1 sensor 1 or 2
o2 sensor bank 2 sensor 1 or 2
Also make sure you don't have a vacum leak.
Jun 11, 2010 | 2000 Ford Windstar
O2 sensors on 1998 ford windstar
1998 Ford Truck Windstar 3.8L SFI 6cyl, there are 4 oxygen sensors on the Windstars They are divided into 2 banks of 2. Bank 1 is the for the rear 3 cylinders of the engine - Bank 2 is for the front 3 cylinders. Bank 1 / Sensor 1 (upstream) is located just below, in the pipe, the exhaust manifold on the back of the engine.
REMOVE TIP: you may have to bend part of the transmission heat shield out of the way - be sure to put it back when done.
Bank 1 Sensor 2 (downstream) is located just past the drivers side catalytic converter.
Bank 2 Sensor 1 (upstream) is located just below the exhaust manifold, in the pipe, at the front of the van - access is from the top.
Bank 2 Sensor 2 (downstream) sensor is located just past the passenger side catalytic converter.
NOTES: * Use lots of penetrating oil - allow to soak - to make removal easier and avoid damaging the exhaust pipe
Hope this help; TY for using Fixya (remember rated and comment this).
Mar 30, 2010 | 1998 Ford Windstar
I have a ford windstar 2001 lx there are four code's i need info
#1 is the egr position sensor #4 Is for single cylinder misfire so this could be the coil or a bad plug or wire ..but with fords should check for a vacume leak that can cause a misfire to .....#2#3 are 02 sensors before i would change them i would check the mass air flow sensor ..Hope this helps
Nov 10, 2009 | 2001 Ford Windstar
O2 sensor location
DTC P0156 indicates the output voltage of the downstream Heated Oxygen Sensor (HO2S) is less than some calibratable functional window. The possible causes are:
  1. Pinched, shorted and/or corroded wiring and pins.
  2. Crossed sensor wires
  3. Exhaust leaks.
  4. Contaminated HO2S.
  5. Bad HO2S.
Since you didnt specify the engine size in your vehicle - please see the diagram below for the location of the sensor(s)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 16, 2009 | 1998 Ford Windstar
Ford Windstar 1996 Trouble Codes P0171, P0141, P0161, and P0174
Bank one is toward the front of the vehicle. Sounds like the heated oxygen sensors have gone bad. The Oxygen Sensors are located in the exhaust pipe and require a special socket to remove and replace.
Jan 16, 2009 | 1996 Ford Windstar
What is PO171 on Ford Winstar 97 3.8 liter
That's an 02/oxygen sensor code means that bank 1 or 2 is too lean. Good Luck contact if you need more help.
Dec 29, 2008 | 1998 Ford Windstar
Obd code P1131 and PO174
P1131 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
P0174 - Fuel Trim System Lean Bank 2
Clean the MAF sensor and check for vacuum leaks at the intake manfold or the injector O rings.
Nov 13, 2008 | Ford Ranger Cars & Trucks
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
