Question about Epson STYLUS R350 Photo Printer
Epson Stylus Photo R350 giving a paper jam error message
I have an Epson Stylus Photo R350. When I try to print (either plain A4, or 6x4 photo paper), the paper part-feeds then stops and I get a paper jam error message. But there is no paper jam whatsoever, no bits of old paper etc in the works. When I then press the Start button as the message directs, the sheet ejects smoothly, then the printer tries to feed another sheet through and the whole procedure starts again. Interestingly, it prints out nozzle check results without any trouble at all! So far as I know I'm doing everything right in terms of feeding the paper in, the printer is level etc. The problem has occurred intermittently in the past but is now full on and throws up the error message every time. Can anybody suggest a solution?
Thanks, Grant.
  • egtaylor Jan 31, 2010
    Nope,not solved after all. The moist paint brush trick isn't working at all today, so back to square one! Help!
  • egtaylor Feb 24, 2010
    Thanks johnnoR,sadly your advice came too late to save my Epson from a trip to the tip. Epson online tech support told me the most likely cause was a paper sensor problem but the local Epson people refused to look at it unless I installed 6 new Epson cartridges at a cost of AUD$30 each (I've used a third party continuous ink supply system for many years with no problems whatsoever) and paid them $99/hr labour plus parts. I was possibly looking at a $300 repair bill. They insisted the problem would definitely have been caused by the non-Epson ink (even though the sensor is located miles away from any ink)! I told them that this was just ridiculous Epson-speak and was so angry at their attitude that I went out and bought a new Canon IP4700 for $138. My wife is delighted because it's much, much faster than the Epson, has duplex printing and is going great guns. Thanks for your advice anyway. Cheers.
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Posted on Feb 20, 2010
Well, maybe it's solved, maybe it isn't!! I found that by lightly brushing the rubber rollers with a moist paint brush (I thought they might have been a bit smooth/worn) the paper fed though fine. After 30 mins when the rollers had dried the problem returned! Further work needed here!
Posted on Jan 30, 2010
Epson Stylus Photo 1390 Paper Jam
It PW sensor error. For "Normal Quality" mode, the PW sensor will not work for "reading" paper existence, but for "Fine", photo and best photo it work. PW is paper widht. Small sensor at bottom side of carriage, near the head. Dirty or short circuit may be.... Can you fix it?
Jan 13, 2013 | Epson Stylus 1400 InkJet Photo Printer
Hi the Epson R350 printer when it prints a photo it is going beyond the size of the photo size with a narrow strip of cyan evenally spaced all the way down the photo like its over printing. It only the one...
There are several potential solutions:
First, see if the paper guidance system is working properly and is aligned properly. It may be a case of misalignment, so the paper is positioned too much at one end so the print heads seem to be going off the page, while in reality the paper is to the side. If the print cartirdge box is aligned as the CMYK model, then the Cyan color is printed on last, with Magenta Yellow and Black spewing out ink onto the paper guiding mechanism.
Second option is print head misalignment, so you'll need to run a realignment procedure from your Epson control panel software.
Third is a drivers issue. Make sure you have the latest drivers that match your operating system, here's the download page http://www.epson.com.ph/epson_philippines/support/eol_product.page?support_name=Epson_Stylus_Photo_R350
If this doesnt help, a general reset of the printer may be useful: Turn off printer, then press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds. A message will appear on the screen. power off and back on for reset.
Jan 02, 2011 | Epson STYLUS R350 Photo Printer
Printing thin black and blue lines across cd
my epson stylus photo r350 prints, but it has a line
Oct 02, 2010 | Epson STYLUS R350 Photo Printer
Epson Stylus R350 in Custom Big Paper
in printer properties, specify the paper size, and or demand for the print to fit paper size, in the printer properties
Mar 22, 2010 | Epson STYLUS R350 Photo Printer
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson STYLUS R350 Photo Printer Logo
645 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
