Question about JVC GR-D30U Camcorder
Shuts down with condensation fault - JVC GR-D30U Camcorder
  • JVC Master
  • 12,061 Answers
Try putting it in a brown paper bag with some silica gel dessicant, or those packs that come with electronic equipment to keep moisture out. Open it up,& leave in a dry warm place for a day or so, & you might get lucky and clear the problem.
Posted on Jan 30, 2010
Furnace blower motor comes on runs for 5 min. then shuts off
ur having a fault issue. check your venting for blockage or the drain tube that drains the condensate
Jun 25, 2016 | Heating & Cooling
BMW x5 3.0d shuts down whilst driving,no fault on the system
Have the injectors checked out .The fault codes will show up on a diagnostic computer.
Apr 14, 2016 | 2009 BMW X5 xDrive
Why does the earth fault breaker shut down when I use my washing machine?
I assume you have checked the earth connection to the ground.usually under sink onto copper pipe.
if there is an intermittent fault on any electrical appliance then the breakers will jump and try to send any residual current to earth to save someone receiving a full force electric shock.
Condensation on the machine electrics could be a good place to start or water reaching any electrics in the same room as machine.this include moisture or damp at the wall socket
Feb 11, 2015 | Washing Machines
Idle air control valve my voyager is idling at 1500 in neutral and 900 in gear. The a/c isnt working either even though its gassed up? The intrument buttons keep flashing and eventually stop. I'm undecided...
before you waste money ,run the fault codes . The ac will not work if it is over gassed or the fan in front of the condenser is not working ( high head pressure switch shuts down the compressor.. You may find a idle speed sensor -MAF/MAP sensor is faulty.
Feb 16, 2014 | 1997 Plymouth Voyager
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
AC Condenser motor will stop at 1pm but inside unit is still running but no AC. If I turn the AC unit breaker unit off and then an hour later turn it back on. The unit runs fine all day until 1pm. Had a...
Hi, the tech should have been able to figure the stat out with out a manual to see why the condenser is shutting off at 1:00 P.M. This is unusual for this to happen, unless it was winter and this is a heat-pump going into defrost, but just the fan would shut down. Does this unit have a box on it that was installed by your electric company that shuts the unit off during high peak conditions in the summer? This would cause it to shut down at the same time everyday. If not, it would have to be something in the thermostat that is set for it to shut off at that time. It still does not make since, as it would shut both the indoor and outdoor unit off, not just the condenser. Are you saying that just the condenser fan motor is shutting off, but the compressor continues to run until it shuts off on high head pressure when the fan stops, or does the complete outdoor unit shut down fan, compressor and all at that time??. It sounds to me like this outdoor unit has a time delay relay that has a fault in it may be shutting it off at this time daily? Please let me know if its just the condenser fan motor that shuts off, or if the complete unit is shutting off all together, this will help .
Sincerely,
Shastalaker7
A/C, Heating,
Sep 08, 2010 | Carrier 38CKC060 Air Conditioner
Compressor runs 45 seconds off for 2 minutes cycles like this no voltage change
In order to accurately determine and diagnose the problem, a more detailed description of the problem needs to be communicated as opposed to normal operation of the system so a repair person can determine that there is in fact a problem. There's a big difference between solving a problem via text as opposed to seeing what is wrong in the field. They rarely are the same.
Goodman condenser sequence of operation on a matched system. Call for cool, condenser starts, 15-30 seconds later blower motor starts, cool satisfied, condenser shuts down, 15-45 seconds later blower motor shuts down. House heats ups and a call for cool via the thermostat starts another cycle.
Based on normal operation it is impossible to determine whats wrong with the information given. There are perhaps 5 voltage measurements in the system that you could be referring to.
Aug 19, 2009 | Goodman Heating & Cooling
Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
JVC GR-D30U Camcorder Logo
194 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
