I'm trying to connect my dvd player to an AWA 47'' LCD tv but it doesnt have any sound although I can see the movie. I have a thick white lead coming from the rear of the dvd player but can't find where to plug it into the back of the tv
  • 12,061 Answers
On the back of your TV, you should have jacks with colors RED, YELLOW & WHITE. Yellow is Video IN. The other two are Left & Right audio IN. Usually they wire up color to color.
Posted on Jan 30, 2010
Screen went black but sound still works.
What kind of input are you using? If you are using 3 cables (white, red, yellow, then possibly your white and red (sound) are still plugged in but the yellow (picture) cable has come lose on the back of the TV or on another machine it is feeding from such as a DVD player or other equipment.
Dec 28, 2011 | Vizio VO47L 47 in. LCD TV
I recently connected a Panasonic DVD player to our 47lg50 LCD television using an S-video cable. I cannot get sound so am assuming I need another cable to connect to the audio out ports on both and dvd...
Yes, you are correct - S-video does not have provisions for audio - it is strictly video. To connect audio, you need two RCA cables, normally colored red and white, right and left respectively. Connect output to input from the source to the destination. The source is the DVD audio out and the destination is the TV audio in.
Dec 16, 2010 | LG 47LG50 47 in. LCD HDTV
How do you connect the dvd player to the lcd
On the dvd player and the tv you will see three (or more) colored connectors. These are color coded yellow, red amd white. One is for audioleft, another for audio right, and the third is video. You can get the cable with the colors so all you need to do is plug the ends into the same color connectors.
thats about as complicated as it gets. Then you need to look at your tv and select source or antenna. That tells the tv where the signal is coming from. you watch your movie and flip the source back to cable or where it finds your normal tv stuff.
You can get the cabes almost anywhere these days. the dollar store around the corner here sells them cheaper than the tv or electronics stores. I think the larger grocery stores even have some. So you don;t need to worry about spending a lot to get good ones. Very little difference in reality. Only thing is to make sure you get it long enough so you can put the dvd where you want or need to and try to get the 3 cable wih color coded ends.
Dec 02, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Video to lcd connection
make sure your dvd player doesnt have a switch onthe back saying something like component or svideo/composite output.. if there is a switch try changing it. if not. you may have to change settings in the players menu. most remotes have a menu button on it. you will want to make sure component mode is enabled/switched
Sep 23, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
AWA DVD PLayer
Try changing the scart lead we have the problem where the scart can cause this.
Mar 10, 2009 | Televison & Video
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Mar 27, 2008 | Sony DAV-S500 System
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
