Question about Bling Software XCopy 9 Full Version for PC
I am getting Error: The encoder has thrown a critical error.It is comming up on xcopy9 and also on xcopypsp.
  • rdoi Feb 01, 2010
    Your solution worked for 2 dvd copies to psp. but now it is supposedly
    copying it to psp but on the psp the error: ? unsupported data is
    showing. Under information: file/mp_root/100mnvo1/m4v20006.mp4.
    I would appriciate a solution to this irritating problem.
    Thanks,
    Ron Doi
    Guru:
  • 458 Answers
It looks like your Xcopy has developed errors.
The files must be corrupted and as a result, it is producing the error you have mentioned.
The most suitable solution would be to uninstall Xcopy and all of its components including Xcopypsp, then install a fresh copy.
This will remove the errors as new error free files will have been installed.
Also make sure that the Xcopy you have is compatible with your Operating System, for example, you you are using Windows XP, it should be a Windows XP compatible version.
Thank you for using Fixya,
Kenneth
Posted on Jan 30, 2010
  • Kenneth Obua
    Kenneth Obua Feb 01, 2010
    It looks like the file"file/mp_root/100mnvo1/m4v20006.mp4." is corrupted or the version of Xcopy is not compatible with your system.
    Did you uninstall all its components?
    After uninstalling, you should delete the folders in the "program files" folder where installed programs are installed to; to remove any residue files left, then make a new installation.
    It is most likely that your system specifications do not match with Operating System (OS).
    What Operating System are you using?
    Did you get a copy which is compatible with your OS?
    If this is not the case, make sure you have a copy compatible with your OS.
    Thank you,
    Kenneth
Magnetic encoding error
try to update firmware. check if driver can read the encoder from a used card.
Feb 19, 2014 | Zebra Office Equipment & Supplies
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hardware Error 0502 displaying on the LCD of my Lexmark X5150
this is an encoder strip error, this is the resolution:
Place an index finger on the encoder strip on either side of the cartridge carrier.
On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
Lightly press the strip first to the rear and then forward, if necessary.
Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
For exended help make your selections at LEXMARK support page:
http://support.lexmark.com/index?page=localeSelect&jumppage=home
Aug 30, 2009 | Lexmark X5150 All-In-One InkJet Printer
Critical error 678 on mobilepro 790
error code is 678 means Ur com port not correct configure so before u connect anything u must to configure correct.
Mar 02, 2009 | NEC MobilePro 790 Pocket PC
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Hey All
This error relates to the encoder strip for the carriage motor. The encoder strip is like a piece of graph paper and the head has an eye that reads how many lines it passes. This is so the machine know exactly where the head is at any point.
The error means that the machine is not correctly reading the encoder impulses. This could be because the encoder has broken, the eye has gone blind or a circuit board or cable has become faulty. It could be that if you have done maintenance that one of the connectors has been replaced with incorrect polarity.
Check the basics first:
  • Is the encoder attached and correctly routed through the optical sensor
  • Is the encoder strip clean - if there is a splodge on it, this will result in error
  • If you have done maintenance, check all the connections you made are good
If you need further help with this, there a good section in the service manual that gives a sequence of areas to test to pin down the fault. Get a manual from http://www.TheServiceManualShop.com
Oct 13, 2007 | Office Equipment & Supplies
Bling Software XCopy 9 Full Version for PC Logo
Top Bling Software Computers & Internet Experts
Edward Talavera
Edward Talavera
Wayne Tolonen
Are you a Bling Software Computer and Internet Expert? Answer questions, earn points and help others
