Question about BenQ FP92W LCD Monitor
Benq FP92W LCD monitor: Backlight fails after approx 5 seconds. One of the 15pf 3KV disc ceramic capacitors was arcing at the top. Replaced the capacitor but fault still there. Unable to identify most transistors on the power board ... one transistor under the board has (slightly) discolored the top of the board ... may have been hot but can't feel any heat there now. Any advice you can give me would be helpful. I don't have a service manual. I am a retired avionics technician. Kind regards, John.
  • jlorr Jan 30, 2010
    If someone has access to a service manual and can advise me what the inverter transistor type numbers are, I would have a real chance of fixing this board. I have the equipment and skills to carry out a component level repair to this board. It's really the challenge ... I hate to throw good stuff away.
    Hi Eagle338 and venexcsd. Ok, now you guys have got me thinking that a replacement board may be the way to go. Thanks for your advice.
    Kind regards,
    John.
    President:
  • 1,185 Answers
Hi, by the time you source the parts and the schematics it will be cheaper to buy a new monitor or s complete pcb
I have used this supplier and found that they are ok
http://www.pchub.com/uph/catf/SearchItem.aspx?ft=laptop+inverter&gclid=CMis7sOfzJ8CFRhp4wodP3rtKg
Posted on Jan 30, 2010
  • 4,889 Answers
When an inverter board fails, a component level repair is usually not possible. Reason? Most of the board's functions are performed by solid state electronics which cannot be repaired. You may be better off replacing the board more so since an inverter board for a monitor of this size costs under 50$
Sai.
  • eagle338
    eagle338 Jan 30, 2010
    You are welcome. Thanks for using Fixya!
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
Best way to open a Vizio LCD monitor LP2626
I have a vizio 26 IN monitor and need to replace the ceramic disc capacitor n3
3kv on the board at c504 but can,t fine them can I replace them with any other
if so what will work I have 10pf 6kv will it work I do not wont blowup my monitor so I need help .Thank You Ed.!!!!!!!
Jul 25, 2011 | Televison & Video
Power not on, power button blinks green power light, doesn't power up. Benq FP92W
It sounds like you have a power supply problem and the safety shutdown has kicked in, the system will need to be checked by a computer tech with an estimate in mind.
Dec 31, 2010 | BenQ FP92W LCD Monitor
How to replace a fuse. Monitor won't power on. Light flashes briefly then goes out.
The fuse is OK because if the main fuse is bad you will not get anything at all. It may have soldered in fuse in the backlight inverter circuits. You have to open it up and troubleshoot it down to component level. So please read my guide first if you are going to DIY repair.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Notes: look for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Post back what you see inside.
Nov 30, 2010 | BenQ FP92W LCD Monitor
When I plug in the monitor the green power LED comes on for approx 2 seconds then goes out. If I unplug the monitor for at least 10 seconds it will repeat the light on for 2 sec. If I unplug it for less...
It can be power supply, backlight inverter, or bad lamp assembly. You need to open it up and do in-depthtroubleshooting. Please read below and look at pictures, learn ablut bad caps, how LCD monitor works.
Basic LCD monitor troubleshooting guide:
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 25, 2010 | BenQ T701 TFT 17" LCD Monitor
Screen will not turn on, unless I turn it on and off at least 50 times, at which point it finally fires up.
You may have dying power supply due to bad DC filter caps, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Sep 08, 2010 | BenQ FP92W LCD Monitor
VGA turns on after afew seconds turns off
Well... it's seems your backlight inverter are busted. Need to replaced or repaired. To repaired, check for faulty capacitors on the inverter. ( For example, like a buldged on top of each caps.) Not sure...just replaced all the caps! Good lucks, have a nice day!
Oct 23, 2008 | BenQ FP71E 17" LCD Monitor
Benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
May 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq fp737s monitor dead
check transistors Q739,740,759,760.What you are refering to are capacitors in powersupply section.These transistors are near the 4 yellow invertors near the backlight connection sockets.
Samir
May 27, 2008 | BenQ FP737S-D 17" LCD Monitor
Screen working and after 2 sec screen black
On your power board you will have a faulty surface mount fet with 8 legs that controls the backlights.
There are 4 of these, but if any of them fail the protection circuit turns them all off.
Best best is to get it to a local technician for repair. It is not an easy task unless you have the right equipment.
Hope that helps. =)
Dec 14, 2007 | BenQ FP92W LCD Monitor
BenQ FP92W LCD Monitor Logo
186 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
