Question about Acer Aspire One PC Notebook
Sometimes when restarting in get into a loop where it's shows very quickly the "blue"screen typical of a system crash (too fast to be able to read anything) and then start rebooting again. It does this for ever until you turn it off and forget about. Latter on, it works...
  • Davis M May 11, 2010
    that's kinda bizarre... One suggestion if it starts the blue-screen reboot-loop hit the F8 key(repeatedly until a menu comes up) before the windows logo comes up, but after the first acer screen disappears. if a white-on-black menu does not show up then you started hitting F8 too late. When the menu shows up, there should be a selection option to do something like "disable reboot on error", "halt on error", or "disable automatic reboot". Select whatever option that is and then continue ahead and see what the error shows itself to be. I suppose, since you're probably running XP... it would be good to either install the Recovery Console, or hookup an external cd/dvd drive and boot from an XP cd and use the Recovery Console, accessible from the first few screens of the XP setup thing. From inside the recovery console, type the following, which are much safter than all the warnings claim... fixboot fixmbr chkdsk /p running those commands have cleared up more laptop BSOD situations than I'd care to remember. That should help, unless you actually have some hardware issue of sorts... Get back to me if there's any issues or results.
  • Acer Master
  • 12,061 Answers
Yes well what you are describing is a classical "BSOD" Blue Screen Of Death... this occurs when the system loads a driver that has a conflict or problem running. If you look in the error logs you will be able to discover why. From this you should/may be able to remedy this. Generally though it is the Video Driver that is having the problem. Or something is unstable in the driver department, Often an upgrade here can be all that is needed. So ensure you have the Most up-to-date BIOS, and MotherBoard Drivers, Video Drivers, etc etc.
Posted on Jan 30, 2010
Blue screen of death on my HP Pavilion g7-1219wm notebook pc
A BSOD (blue screen of death) is a general failure warning and in itself is not serious unless it continues to happen. If that is the case, you will need to read and write down the message that appears to be able to get further help.
Jan 19, 2013 | Pavilion g7-1219wm Notebook PC
Sometimes,,when I open my pc,,there is a blue screen appeared after the windows xp logo and it restarts again after a few seconds..you cannot read the error because it restart fast
Follow the steps below to capture the blue screen error code.
1. Turn the computer on.
2. Keep tapping F8.
3. On the Advance Boot Menu, use the arrow keys to select Disable Automatic Restart on System Failure.
4. Press Enter.
The next time that the blue screen shows up, it will be paused and you can get the error code. Let us know what type of error code you are getting and we will be more than happy to help you out.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
My pc wont boot up normally, it has a blue screen show up but then it goes away before i can read it
The blue screen of death BSOD is set to auto-restart after an error you can change the registry to prevent this not sure if you can do this in safe mode but its worth a try you will at least be able to see the error.
Its a good idea to use MemTest on a boot CD to check your RAM for errors first then restore from an old image.
Feb 07, 2010 | Acer Aspire One PC Notebook
Blue screen error message (Crash Dump)
kernell has over run the memory....
some corrupt registries may also cause this issue...
u can try to run a registry cleaner (Tuneup Utilitis or Registry defrag etc can do the job...search in google)
else
do a clean install of OS after data backup
Dec 14, 2009 | Computers & Internet
Hello I have an acer aspire 5535 and it keeps
The complete solution to this fault (Acer 5535 keeps crashing under vista) is to use Windows XP instead of Vista. Set up a Dual Boot so you can CHOOSE to load XP or Vista each time you turn on the laptop. I've put XP on my 5535 and it's SO much faster and seems perfectly stable now - no crashing at all.
A full video showing how to do this is here: http://www.youtube.com/watch?v=rdfU9TXIAd4
Once you've done this you won't have any problems with the laptop anymore.
This is a perfect solution to the crashing problem!
Jun 05, 2009 | Computers & Internet
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
Error window when starting windows xp
restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
Feb 02, 2009 | Toshiba Satellite M50 Notebook
Zero error
Ok. When it shows the screens, can you read the text or does it go away fast...
Close to the bottom you will see a number... See if you can give it to me...
Maybe it is a Memory Problem... According to the number you give me, i will let you know..
Jul 20, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
