Question about Kenmore 13759 / 13754 / 13752 Dishwasher
Dishwasher 13759k clean lite blinks seven times . nothing else works.
  • 770 Answers
This is a known problem plz follow this link
http://www.servicematters.com/docs/doc_main.htm
plz rate me as well
Posted on Feb 17, 2008
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean light blinks seven times and will not start on any cycle.
The problem you are having is that the dishwasher is sensing that the water is not getting hot enough to finsh out the cycle. The first thing you need to do is get the dishwasher into diagnostic test mode, you can do this by pressing: normal wash then heated dry, 4 times. After in diagnostic mode you can exit out by pressing cancel/drain. This will get rid of the blinking clean light and the washer can be operated in any cycle now. To prevent this light from coming back on, you can do one of two things. First you can just try running Hot water at the faucet before each time you use the dishwasher. Or, you can replace the thermistor/sensor that senses the water temperature. You can purchase this part at this link http://www.repairclinic.com/Sensor-Or-Thermistor-Parts?s=t-DU1055XTS-%3d%3dc61
Nov 27, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Green light on clean cycle is blinking seven times - cannot reprogram it
this usually means the chopper blade is broken or the sump screen is plugged. you will need to disassemble the sump to check
Jan 31, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Won't fill clean light blinks seven times
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
I have often found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. You will need to refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 30, 2009 | Dishwashers
Kenmore DW blinking clean light 7 times, pausing, blinking 7
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
Oct 11, 2009 | Dishwashers
Whirlpool quiet partner 1 # DU1055XTSQ2
Read this article, it should address your problem.
http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
http://tclaundryrepair.com/
Feb 24, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
I need an exploded view of whirlpool dishwasher
something in the heater circuit -or- the motor has died. I found the front bearing on mine was toast.
Jan 18, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
114 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
