I have installed the satellite dish according to the manual and have a good signal strength however it still can't find any channels. the Error message 52 comes up saying there is a technical problem. I have double checked everything and it all appears as per instructions. Austar will not help us as we live in an owner install area. what do I do?
  • 2 more comments
  • andrewandtas Feb 01, 2010
    Sorry I was not very clear in my intial post. The dish we are installing is a Austar owner install kit. Because we live in the middle of woop woop there is no one that will come out here to install our dish etc. So we used all new cable however not sure which size as is just what was provided and no splitters were used. There are 3 other dishes in this community on different houses and the last bloke to install his got it no trouble. It doesn't make sense we have followed all the instructions to the letter. When we have the lttle signal finder box plugged in to the line we can get a signal strength of 100 then we unplug it to plug the main line back in and it drops to about 49. Austar refuse to help as it is owner install and not there problem. The only thing they said was we are on the wrong satelitte but there is no other satelite signal out there in the north - east quad. Hope this makes it all as clear as mud and you are able to help us a bit.
    Cheers
    The make of the dish is a Optus C1 as supplied by austar.
    Thanks, we haven't tried swapping recievers yet. I have spent ages sitting on the couch while my hubby adjusts it manually and I yell out the signal strength as it changes. Even when he magically got it at 100% it still couldn't find any channels after resetting it. We'll try swapping recievers and see how we go.
    Thanks again.
    Cheers I will check all these things with my husband tonight. I will leave this problem open for now incase we still have no luck and I nedd to come back for more info.
  • 8,197 Answers
I install dishes for a living. I have a couple of questions for you.
1. Did you run a new line to the house from the dish to the receiver.
2. Did you use a splitter in between the dish and the receiver.
3. What size coaxial cable did you use.
Here are the way the answers shooed be to each question above.
1. Yes instaled new wire to receiver. If No we need to talk.
2. No I did not use any splitter's to go to other TVs. If yes we need to talk
3. RG59 or RG6 coaxial cable.
Also can I get the make and model # of reciver and service provider. Is it Dish Network or Direct TV.
Posted on Jan 30, 2010
  • 2 more comments
  • Jyackle5
    Jyackle5 Feb 01, 2010
    Have you tried to reset the receiver with the button in front. Also you might want to talk to the neighbor and see if you can take your receiver down to his house to see if it works. Also I do not trust the signal finders they do not work. You need to have the signal up to at least 65% or better to have the receiver work. Try the way I do it buy having someone in the house watching the signal meter as you adjust the dish to get max signal. Will be online for about 3 to 4 more hrs if you need help.
  • Jyackle5
    YEs I would try the neighbor's receiver to see if it works. Or take yours to his house to see what happens. You might have a bad receiver. If the neighbor's receiver works at your house then it is the receiver. If it does not then there is something wrong with the wiring. Also when you tack the wire to the house make sure that you do not put a nail in it or you can get the same problem you have now.
  • Jyackle5
    One more question did you put the ends on the cable. If so make sure that there is no small wires touching the center copper wire if you look down the end where the screw fitting. If so that will ground out the signal and you will not get picture.
  • Jyackle5
    No problem Just let me know if you have any questions. I will be off line at 10:00pm PST. will be back tommarow after 3:30 pm. It is 9:45 pm now
I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Nov 17, 2013 | Televison & Video
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    Can't get to correct channel for satellite reception
    Use the menu button on the face of the receiver. Go to settings-satellite-signal strength-view signal meter. At that point, if your readings are zero, it's one of of four things: misagligned dish, defective LNB, defective cable/fitting, defective receiver.
    Aug 21, 2012 | Emerson EWF2004 20" TV
    Dish network error 004
    Hi there, Tim!
    It's possible the dish may need to be repointed. Try running a check switch test. Go to Menu > System Setup (6) > Installation (1) > Point Dish (1) > Check Switch > Test. This will provide more info on the satellite signal.
    If you have run that test and the problem continues I would need to see about getting a tech out. If so, you can send me an email at thomas.faust@dish.com for further assistance!
    Tommy Faust
    DISH Social Media Representative
    Mar 25, 2012 | DISH Network 625 Duo DVR Receiver...
    We have a problem with one of the channels - when we try to watch it the picture pixelates and there is a nasty popping sound :(
    If you are using a satellite receiver for cable TV reception, that particular channel has low signal strength coming into the receiver from the dish antenna. Realigning the direction of the dish might improve the signal but make sure you do not have the same problem on some other OK channel.
    Mar 08, 2011 | Televison & Video
    My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
    Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
    Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
    Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
    Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
    Jun 25, 2010 | DISH Network 322 DTV Receiver
    Local channels are fine all other channels break up looking for satellite
    You may need to re aim your dish because you are having a low signal strength issue. Check for new tree growth in the line of site. If that won't help you can replace the current dish with a larger one. Say 18" to a 24" would give a lot more signal strength which will help with that kind of a problem.
    Good luck
    Rich
    Jun 06, 2010 | Televison & Video
    With the bell dish we have the oblong dish can get 100% signal for satelite 91 and 100% on satelite 82 but not both at the same time?
    Guest 10
    With multiple satellite dishes, you will get a lower signal strength on mulitple satellites as opposed to individual satellites. The reason being when pointed at one satellite, you are pointed directly at that satellite. With multiple satellites, you are pointed in the general direction of the multiple satellites so the signal will not be as strong compared to pointing directly at the individual satellite. Normally, a signal strength 50 or above is sufficient. I hope this helps.
    Ray Calo
    DISH Network
    May 20, 2010 | DISH Network IR Remote Control
    Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
    Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
    It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
    If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
    One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
    Hope this helps!
    P.S.
    The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
    Mar 25, 2009 | Televison & Video
    Televison & Video Logo
    Top Televison & Video Experts
